Old 12th May 2008, 01:05 PM   (permalink)
Default Need A Simple Timed Relay
I´m pretty much a noob, but I think this should be fairly simple, I just need a simple design that will activate 2 small relays at a variable interval, say 5 - 10 minutes. Specifically I want to replace the momentary contact switches in an air conditioner control panel with the relays and then have them switch on and off every few minutes (cycling between fan and cool). I´m thinking two normally open 3-8V DC relays run by a circuit that is powered by a couple of AA batteries or maybe a 9V . They would need to switch on for probably about only a half second or so. The timing cycle adjustment does not need to be anything fancy, maybe a vairiable capacitor or something? Appreciate the help
chads is offline   Reply With Quote
Old 12th May 2008, 04:17 PM   (permalink)
Default RE: Need A Simple Timed Relay
When I first saw this topic, I thought it was something that needed a short delay and was going to recommend using a 555 Timer circuit, but then I read what you were going to do, so I would recommend using a PIC microcontroller for what you need. I'm a noob too so, don't feel bad if I can't give you any more information on what you need for your switching relay circuit.
This is the way the world ends,
Not with a BANG
But with a BELCH
BURRRRRRRRRRPPPPPPP
skeeterb is offline   Reply With Quote
Old 13th May 2008, 02:08 AM   (permalink)
play with this one i would say
you can adjust the suply voltage if you change the potentio meter the time cycle will change also picking a different output of the IC will vary in duration
no mater which out put you take the up time is exacly the same as the down time
the transistor choice is depending how much your relais consume
so look at the data sheets for the IC 4060 and the transistors to fill in the blank spots
sucsess with building it
Robert-Jan
rjvh is offline   Reply With Quote
Old 13th May 2008, 02:15 AM   (permalink)
The 4XXX series of CMOS Logic ICs seem to be one of the most flexibles ICs out there, IMHO. I have a circuit myself that uses a 4011 and 4093, but If I were building a circuit like yours, I would take the recommendations of the more experienced users here on this forum. I would also listen to any other suggestions your fellow members would make to help you get your circuit working.
Not with a BANG
But with a BELCH
BURRRRRRRRRRPPPPPPP
Old 13th May 2008, 02:16 AM   (permalink)
oops to hasty forgot the shematic
Robert-Jan
Old 28th May 2008, 03:33 AM   (permalink)
That tmp3.jpg may be too small to read, as it is here.
stevag is offline   Reply With Quote
Old 3rd June 2008, 08:04 AM   (permalink)
Klick on it with you mouse and it gets bigger
thats the magic trick you have to use
Robert-Jan
Simple switching/pulse project dbtoutfit Electronic Projects Design/Ideas/Reviews 2 1st November 2007 01:46 PM
relay activation using IC or any circuit jaikanth General Electronics Chat 3 28th December 2004 11:32 PM
relay not activating gjpollitt General Electronics Chat 3 15th January 2004 06:55 PM
Incubator Relay Circuit Plip Electronic Projects Design/Ideas/Reviews 2 26th November 2003 12:35 PM
Relay Question....... Shocky Electronic Projects Design/Ideas/Reviews 8 23rd November 2003 08:42 PM
