I wish to build a switching power supply, input - 230Vac, 50Hz, output - 13.8Vdc (or 15V) and 8 Amp, instead of the conventional linear power supply. I am a new member and new to switching power supply. Appreciate an applicable and 'simple' circuit for such type of power supply from any kind soul. Regards |
www.powerint.com has simple and good devices like TINY and LNK series, please see the site and they have lot of application notes.
there are many others like ST Micro's viper50,
Regards, Sarma. |
I think for such power you'd rather need the TOPSwitch family, TINY family is for much smaller power supplies.
But if you are new to switching power supplies I don't think this is a good project for a start, complicated and can be even dangerous. Better to start e.g. with a buck controller - look at National Semiconductor, ON Semiconductor .... Petr |
After reviewing viper, power int., it seems getting special type of transformer is rather inconvenient. ST L4970A may be a good option to convert 230Vac (rectifying 28Vdc), 50hz to (0 to 25Vdc and 10A). And this is fed into pin 9, Vin. The question is what current input. Referring to some design options, it appears the input should be V0 times I0 div by Vin (V0 and I0 are output voltage and current) which is 25x10/40 =6.25, convert this to rms current 6.25/1.414 = 4.42 Amp ac. Hence transformer VA is 28 x 4.42 about 124VA. As this is the first time I am using this type of switching regulator, welcome any one who has this experience to review and comment. |
Even then you might need an inductor of good current carrying capacity, I believe. The transformer would again be bulky at the 50Hz point.
Regards, Sarma. |
Hi Sarma,
Went into power int (PI), design the circuit and forwarded to PI but they could not support transformer and inductor locally (Singapore), based on the design needs. Search around and found L4970A a switching regulator. Attached is the design using L4970A and expanded my required output voltage and current supply from 7A to 10A. Agree, base on this design the transformer needed would be bulky again, not so much as before using conventional transformer and rectifier without switching regulator. If somebody in Singapore can supply those PI transformer and inductor, it would be most welcome. |
If so please see the other site where audioguru has moderated a circuit to give upto 5 amps.
Regards, Sarma. |
there are a number of companies now that supply some of those transformers.
Of course the daring could roll their own. I do tend to prefer planars myself, but it is not easy to cut good windings and most do not have access to thin PCB core for the primary windings. One thing to watch out for is the reflected voltage: you will have upto about 400V on the supply plus the output multiplied by the turns ratio to the FET. |
Hi Ubergeek63,
Mind giving me details of these companies providing those transformer as detail in attachment. Hope some soul or companies in Singapore who are willing to sell them. |
Planar transformers Planar magnetics Planar Technology
http://www.coilcraft.com/pdfs/pl140.pdf You generally will not find them in apps for AC line apps because most off the shelf units do not pass the safety isolation requirements. (5KV isolation is not easily to get in such a small package. While I have done it, there is not space for high isolation and high current) |
Hi Ubergeek63,
Visited ww2.pulseeng.com, Pulse Technitrol Company, and contacted its local administrator. All supports are out of town. I am looking for a suitable Planar transformer and workable regulator and circuit to convert 230Vac to anything equal or more than 18Vdc, 10Amp. Appreciate any recommendation. |
you will never be able to walk into a store and get a 200W switching transformer or a 300VA (what you would need for 50-60Hz) transformer.
I can design the things, but they still have to be built. You either need to order from a company who makes them, where ever they may be, or order a 50Hz unit from someone who has them and pay the shipping. Last edited by Ubergeek63; 23rd May 2008 at 05:03 PM. |
What capacity batteries you wanted to us the charger for?
Regards, Sarma. |
It is for powering something else, not for charging.
There are standard off the shelf 250Watt Planar transformer, but I need a matching regulator and associated circuit, as Planar is new to me. Reason for going for planar is that it is compact and much lighter than a traditional transformer, rectifier and etc. As for pure switching power supply, special wound transformer is needed. |
Please see this pdf http://www.rason.org/Projects/powsupply/powsupply.pdf
Regards, Sarma. Last edited by mvs sarma; 24th May 2008 at 12:53 PM. |
| Switching power supply issue. | dbtoutfit | General Electronics Chat | 41 | 25th March 2008 03:21 AM |
| Switching power supply 12v to 13.8v | dbtoutfit | General Electronics Chat | 19 | 31st January 2008 05:51 AM |
| Got a new EVBoard How do i supply power to it? | cubdh23 | Micro Controllers | 2 | 3rd August 2007 09:39 AM |
| Using a computer power supply WITHOUT a computer? | grrr_arrghh | General Electronics Chat | 13 | 4th April 2007 12:15 AM |
| Power supply/ current supply design | inkedallusion | Electronic Projects Design/Ideas/Reviews | 1 | 17th December 2002 01:10 AM |
