| Yes, you are correct, L4970A can do the job, but again the transformer would be somewhere 100VA for a 18Vdc and 10Amp (I up the required output). This is like meeting the traditional power supply and the switching power supply half way. Well, if I continue to have problem getting matching regulator IC versus the off the shelf planar supplied by Pulse Engineering or Technotrol company in Singapore, I may revert to L4970A. Appreciate any kind soul could help. | |
Perhaps please see whether you can salvage a TV power supply and try to rewire the Ferrite transformer with suitable secondary winding. It would nearly meet your needs.
| Hi, Attached the off the shelf planar transformer from Pulse Engineering. Any kind soul could help match the regulator IC and circuit for these Planar models detailed in the attachments. | |
__________________ I also post at the following sites: http://www.stop-microsoft.org http://www.heated-debates.com Screen name: Aloone_Jonez And http://www.silicontronics.com, same screen name as here. | ||
I typed wrongly 150 watts -- it should have been 550 watts. Neither a normal TV SMPS core would do for this. Yes Hero999, I too worked with 5KW SMPSs in the Indian Telecom scenario. We used to stalk 3 of them, one across each phase (230V 50Hz) and thus balance the load on public mains for a 300Amp 50V DC power needs of telecom switches in villages.
__________________ Regards, Sarma. Last edited by mvs sarma; 24th May 2008 at 04:30 PM. | ||
| please see this product and I feel it is rather cheap . One can verywell manage with it unless one has to make it by himself. 12V 13.8V DC 12 Amp Regulated Switching Power Supply - eBay (item 350062751166 end time May-28-08 22:17:34 PDT)
| Hi Sarma, I live in Singapore. I had some experience with China made switching power supply, which cost about S$100, US$77. It say adjustable 0 to 24Vdc and 10Amp. In reality, adjustable to 16Vdc and 4.5Amp. Thank you for following this thread closely. Just want to be assured, did you know of anyone who had use this brand. Please let me know their experience. Meanwhile, Hero base on the attached Planar information appreciate any circuit and IC recommendation. | |
| My Idea Is To First Use A Hi Voltage Preregulator For 180v To Insure That The Power Will Not Go Away When It Dips And Bounce. Then Use Low Voltages Pwm To Get The Current | |
| ok, this sound interesting. please post schematic of the circuit. | |
| Off-line switched PSUs can be designed as "universal" - working in the 85V - 265V range. That would make the preregulator unnecessary. | |
| every stage counts on your pocket and also on power efficiency. It is always better to work a one time solution. Unless one is going for a project, i still feel the site indicated by me sells a psu very cheap.
| My suggestion was with specific reference to L4970A chip and the schematic there on provided by the OP. There after the OP wanted to use Planar transformers-- i was confused with low height CRGO core transformers --some of them I saw in light dimmers( Really sleek and wide.)
| Although he'd need to use some inrush current limiting to avoid destroying it.
| Switching power supply issue. | dbtoutfit | General Electronics Chat | 41 | 25th March 2008 04:21 AM |
| Switching power supply 12v to 13.8v | dbtoutfit | General Electronics Chat | 19 | 31st January 2008 06:51 AM |
| Got a new EVBoard How do i supply power to it? | cubdh23 | Micro Controllers | 2 | 3rd August 2007 10:39 AM |
| Using a computer power supply WITHOUT a computer? | grrr_arrghh | General Electronics Chat | 13 | 4th April 2007 01:15 AM |
| Power supply/ current supply design | inkedallusion | Electronic Projects Design/Ideas/Reviews | 1 | 17th December 2002 02:10 AM |
