| New Member | i have been building inverters (single phase 220v) using mosfets and controll circuits and they really works but my biggets problem now is that my people are now requesting for bigger invertters like 25kva-200kva, what i am now facing is the size and the look of how the finnished product will be if i continue with the use of a transformer. |
| Experienced Member | Quote:
As you are making inverters, i hope that you might be a qualified person. lease re-collect the rule-- "energy can neither be created nor...." so if you want inverter at such high wattage, you have to afford volume and higher power devices. Only way ito reduce size of magnetics is to choose High frequencies, in the order of MHz. I am not quite sure whether devices and cores are available at such high wattage. Then why not try distributed inverters housed in one cabinet. How ever the outputs need to be isolated. This gives you redundancy.
| New Member | thanks i read your msg, and i think the solution is to build a transformerless inverter that takes a battery bank of say 300volts dc and switch to 230vac, but i have little or no idea of how to go about. still i will like to show u what i have done so far using a 2 anode transformer. Pls i will love to have your mail address so i can send it to you thanks |
cells who deliver the 700 amp are available but so far i know only in 2 volt which makes it roughly 150 cells and they are not a bargain is it not cheaper to think in terms of generators if you want that amount of power how you gonna charge the batterys your charger is gonna be a problem also Robert-Jan | |
| "Electronics For You" Magzine readers ,, PLS HELP !!!!!! | shubhamjain_007 | Electronic Projects Design/Ideas/Reviews | 7 | 10th April 2008 01:12 PM |
| guidance pls!!! | sid3147 | Electronic Projects Design/Ideas/Reviews | 2 | 5th March 2008 04:52 PM |
| HELP HELP!! some question related to my homework pls help~ | anzdyy | Electronic Projects Design/Ideas/Reviews | 15 | 2nd March 2008 02:08 PM |
| need to isolate two grounds in my circuit.. | raviram87 | Electronic Projects Design/Ideas/Reviews | 13 | 17th February 2008 03:37 AM |
| hi...pls help | Anushya | Datasheet/Parts Requests | 1 | 17th December 2007 04:00 PM |
