Old 10th May 2008, 09:18 AM   (permalink)
Alston_villa is on a distinguished road
Default How to build a variable voltage supply(with requirements)???
Variable Voltage Supply requirements: This should be made from an op-amp and a MOSFET (not a
commercial regulator chip). It should provide an output voltage of 0-5 V at 500 mA,
adjustable using a potentiometer. You should test the transient performance of the circuit by
switching on and off a load using a second MOSFET as the switch driven from the Function
generator. You may also like to tailor the overload performance.
Any ideas? The circuit should be linear regulated.I looked at the circuit in http://www.electronics-lab.com/proje...011/index.html but BJTs were used instead of MOSFETs and no opamps were used.I've also looked here http://tangentsoft.net/elec/opamp-linreg.html but I'm not sure how to modify the circuits to match my requirements.The circuit shouldn't be too complex or complicated.Any help will be greatly appreciated.Thanks.
Alston_villa is offline   Reply With Quote
variable voltage power supply mahmoud shendy General Electronics Chat 8 28th December 2007 05:22 PM
Using Oscilloscopes mechie Electronic Theory 9 29th November 2007 09:48 PM
Voltage ElectroMaster Electronic Theory 44 8th August 2007 05:35 PM
Voltage controlled amplifier Jimbo Electronic Projects Design/Ideas/Reviews 2 20th October 2003 12:24 PM
should i use a voltage regulator on a wall transformer. macman828 General Electronics Chat 3 22nd April 2003 07:10 AM
