| New Member | Variable Voltage Supply requirements: This should be made from an op-amp and a MOSFET (not a commercial regulator chip). It should provide an output voltage of 0-5 V at 500 mA, adjustable using a potentiometer. You should test the transient performance of the circuit by switching on and off a load using a second MOSFET as the switch driven from the Function generator. You may also like to tailor the overload performance. Any ideas? The circuit should be linear regulated.I looked at the circuit in http://www.electronics-lab.com/proje...011/index.html but BJTs were used instead of MOSFETs and no opamps were used.I've also looked here http://tangentsoft.net/elec/opamp-linreg.html but I'm not sure how to modify the circuits to match my requirements.The circuit shouldn't be too complex or complicated.Any help will be greatly appreciated.Thanks. |
| variable voltage power supply | mahmoud shendy | General Electronics Chat | 8 | 28th December 2007 05:22 PM |
| Using Oscilloscopes | mechie | Electronic Theory | 9 | 29th November 2007 09:48 PM |
| Voltage | ElectroMaster | Electronic Theory | 44 | 8th August 2007 05:35 PM |
| Voltage controlled amplifier | Jimbo | Electronic Projects Design/Ideas/Reviews | 2 | 20th October 2003 12:24 PM |
| should i use a voltage regulator on a wall transformer. | macman828 | General Electronics Chat | 3 | 22nd April 2003 07:10 AM |
