Old 10th May 2008, 03:23 AM   (permalink)
mltj74 is on a distinguished road
Default load failure warning
i was woundering if anyone knew a circuit that would light up a led when a load quit working like say a pump quit working
mltj74 is offline   Reply With Quote
Old 10th May 2008, 05:25 AM   (permalink)
Experienced Member
rjvh is a glorious beacon of lightrjvh is a glorious beacon of lightrjvh is a glorious beacon of lightrjvh is a glorious beacon of light
what kind of pump/motor ?
normaly you have thermal overload protection with auxilary contacts that you use for a indicator light or alarm
or you need a status indicator (on/off) light
than you switch it with the contactor contact
Robert-Jan
rjvh is offline   Reply With Quote
Old 10th May 2008, 03:52 PM   (permalink)
its a 12 volt fuel pump and i would lie to use it on some 3 way valves also if anyone of these failed it could cause some major damage i would just like a indicator light in my cab to let me know one of them failed
Old 12th May 2008, 01:02 AM   (permalink)
Experienced Member
its just the motor that you want have an indication or is it if one of the valves failed that you want to have an indication??? or both??
Robert-Jan
Old 12th May 2008, 02:42 AM   (permalink)
both so i would like a circuit flexable enough to use with both making 3 or so different circuits for each load wouldnt be a problem
Old 12th May 2008, 03:39 AM   (permalink)
Experienced Member
do you use solenoid valves???
Robert-Jan
Old 12th May 2008, 08:32 PM   (permalink)
Experienced Member
Leftyretro has a spectacular aura about
Or do you really want a final control element alarm when there is lack or low fuel pressure? A pressure sensor would give the best overall alarm that something is wrong, without having to have several sensors to detect problems on individual stages and parts and peices of the system.
Lefty
Measurement changes behavior
Leftyretro is offline   Reply With Quote
Old 12th May 2008, 09:26 PM   (permalink)
pressure gauge is no good the light or alarm would be going off all the time theres no pressure differnce between big mess and normal operation and yes they are solenoid valves
AC Voltage Meter pursang General Electronics Chat 11 27th January 2008 01:34 PM
Inchworm adapter bd lemonyx Micro Controllers 9 9th May 2007 07:01 AM
Validating Code Without PIC burg Micro Controllers 4 22nd April 2007 04:14 PM
Motor Torque watzmann General Electronics Chat 5 8th September 2005 01:26 AM
Crazy Resonance Problem cchalmers General Electronics Chat 31 14th February 2005 03:46 PM
