Old 11th May 2008, 06:34 PM   (permalink)
Experienced Member
audioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to behold
You have been given high voltage low current Mosfets. The inverter needs high current low voltage Mosfets.
The transformer is too small.
All the parts are wrong for that extremely simple circuit.
With the low current Mosfets and tiny transformer then your project might light a 230V 7W night light dimly. I doubt its square-wave would power a clock radio.
Who is doing the project? Them or you?
Old 11th May 2008, 09:27 PM   (permalink)
Experienced Member
JAMES IRVINE is an unknown quantity at this point
It's a cowboy college who cut corners with everything, well thanks for telling me now I know I need new components, at least now I wont look stupid building it. The thing is I've did a lot on theory, I've more material than anyone on my course so I should at least get a pass and thanks to you now I can get on there nerves by pointing out how they messed up.
Just out of curiosity and ignorance how easy are these components to get from high street shops and how much cost would I be looking at.
JAMES IRVINE is offline   Reply With Quote
Old 11th May 2008, 09:41 PM   (permalink)
Experienced Member
You could make this extremely simple inverter for about 5 times the cost of buying a new modern modified sine-wave one that has a lot more power and a display showing the power output and current used. But they are made in China so they might not last very long.
Old 13th May 2008, 08:37 AM   (permalink)
Experienced Member
Well the college has told me that I should just use a 12 watt light bulb for the load, that will work with a squarewave anyway wont it. Thanks for the info Uncle scrooge, they told me to stick with what I have and stop worrying about it so if it doesnt work it's not my fault. Told you it was a cowboy college.
Old 13th May 2008, 09:20 AM   (permalink)
Experienced Member
ericgibbs has much to be proud ofericgibbs has much to be proud ofericgibbs has much to be proud ofericgibbs has much to be proud ofericgibbs has much to be proud ofericgibbs has much to be proud ofericgibbs has much to be proud ofericgibbs has much to be proud of
hi James,
The 12Watt should be OK for testing, the transformer is 12Vac * 2 = 24VA[watts]
I hope you win your 'spurs' when you submit your assignment...
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
Old 13th May 2008, 03:52 PM   (permalink)
Experienced Member
If the 12W bulb is an electronic Compact Fluorescent Light Bulb then it might not work from the square-wave from the simple inverter circuit.
I have never seen a 12W incandescent light bulb that will work.
Old 14th May 2008, 06:50 AM   (permalink)
Experienced Member
Any suggestions for a load uncle scrooge.
Thanks Eric for the encouragement, a lot of my good knowledge about circuits is down to u and uncle scrooge so thanks for that.
I thought I might as well say it come on the Glasgow Rangers.
Old 14th May 2008, 10:24 PM   (permalink)
Experienced Member
I don't know any electrical device that operates with only 12W.
The inverter might power two 5W or 7w incandescent night light bulbs.
Transformer Question firealarmfreak Electronic Projects Design/Ideas/Reviews 5 3rd March 2008 01:39 PM
Inverter Transformer delta06 Electronic Projects Design/Ideas/Reviews 1 3rd December 2007 02:38 PM
Transformer Problems? MsStateDawg Electronic Projects Design/Ideas/Reviews 15 2nd November 2007 10:17 PM
Circuit Design: Transformer (or Inverter?) jrod5000 Electronic Projects Design/Ideas/Reviews 5 2nd November 2007 04:51 PM
Inverter Mosfets - Burning Hot Sarac General Electronics Chat 3 4th March 2003 04:11 PM
