| Electronic Projects Design/Ideas/Reviews Are you building an electronic project or want to? Maybe you need some assistance? Come and submit your electronic questions here and let our exprienced members find a solution. |
| | Thread Tools | Search this Thread | Display Modes |
| New Member | I have a project that I’m working on and need a bit of direction here. I need to power 155 laser diodes rated at 650nm 5mA, 3.2 v. The diodes run at around 30mA each. I bought this power supply http://www.trcelectronics.com/Meanwell/pdf/rs35.pdf Do I just use a triple pronged extension cord, cut off the end, then: - place the live wire into pin 1 (L, AC) - neutral into pin 2 (N, AC) - ground into pin 3 I have a 6ft extension cord: 13A - 125V - 1625W Or am I way off here? Any problems I need to be aware of? Thanks for any help... |
| New Member | Thanks Gayan, Those diodes are going to be connected parallel (all positives together/all negatives together?). Here is the thread that explaines how the diode was tested; http://regrowth.com/hairloss-forums/...fm?f=1&t=20527 Note: a diode was tested at 27mA with a 5.2v adapter. 30mA is just an approximate... ![]() Last edited by Willie TwoFinger : 9th May 2008 at 08:38 PM. |
| Experienced Member | If you tell us the name of the manufacturer and the part number of the laser diode assembly then we can look it up immediately without waiting for e-mails. www.datasheetarchive.com and Google have never heard of the HLM-8013B.
__________________ Uncle $crooge |
| Experienced Member | Quote:
| Visual Basic for Electronics Engineering Applications | ThermalRunaway | Electronic Books | 18 | 24th March 2008 08:36 PM |
| It is BASIC or is it BABL | 3v0 | Micro Controllers | 22 | 7th May 2007 02:09 PM |
| free pic basic complier | dstich | Micro Controllers | 7 | 1st August 2006 07:13 PM |
| Assembly to Basic Coding | AZdave | Micro Controllers | 3 | 23rd January 2005 02:28 PM |
| PIC basic and Basic stamp | Cyborg | Micro Controllers | 5 | 21st April 2004 08:44 AM |
