| Electronic Projects Design/Ideas/Reviews Are you building an electronic project or want to? Maybe you need some assistance? Come and submit your electronic questions here and let our exprienced members find a solution. |
| | #16 (permalink) |
| Experienced Member Join Date: Mar 2004 Location: Canada, of course!
| Many laser diodes have a photo-diode inside that is used with an external transistor to adjust the brightness. I don't know if these laser diodes have the feedback transistor and I don't know how much extra voltage the transistor needs. The transistor also might limit the current. The datasheet for the laser diode assembly will tell all.
__________________ Uncle $crooge |
| | #17 (permalink) |
| The "manufacturer" AixiZ Service & International, LLC is just a distributor for 184 companies that make laser diodes and many other optical items. The search on the website did not know of the part number for the laser diode.
| | #18 (permalink) |
| New Member Join Date: May 2008
| Torben... thanks for all the info, it is clarifying much for me... audioguru... yeah I was thinking that would be the case. I'm pretty sure that they're actually made somewhere in China. I couldn't find that info on their web site.... Last edited by Willie TwoFinger; 11th May 2008 at 02:36 PM. |
| | #20 (permalink) |
| Another question has come up... "We need to find out the formula for the amps when we wire it series/parallel. Is it just straight up division? If I had lets say 200 diodes wired into four groups of 50 -and each of those four was wired series, and I used a 12 volt adapter- then would the total amps be 1/4th what it would be?" |
| | #22 (permalink) | |
| Experienced Member Join Date: Oct 2006 Location: B.C., Canada
OK, for this I'm going to assume we're just using bare LEDs here (not laser modules with integrated electronics). Assumptions: all LEDs are 3.2V LEDs which want 50mA; we have a 12V power supply. So Vled = 3.2V; Iled = 50mA, and Vsupply = 12V. The short answer to your questions is "No, the total current drawn would not be 1/4 of of just wiring them all up in parallel. It would be 0." That is, 200 3.2V LEDs wired in 4 strings of 50 LEDs each would not even try to light up from a 12V power supply. Remember that you need (Vled * number of LEDs per string) volts to run the thing. (3.2 * 50) = 160V. You are not going to get a 160V device to run on a 12V power supply without some kind of boost converter. If you used a 160V+ power supply then the current draw would be 200mA (50mA * 4). With a 12-volt supply your longest string of LEDs can be 3 LEDs long. Why? Because 3.2V goes into 12 at most 3 times. So you could do 66 groups of 3 LEDs (with 2 LEDs left over), or 100 groups of 2 LEDs. Make sense? Torben | |
| | #24 (permalink) |
| Everybody is just guessing without detailed spec's. The laser assemblies might need external current-limiting or not. What is their minimum and maximum allowed voltage and current?
| Visual Basic for Electronics Engineering Applications | ThermalRunaway | Electronic Books | 18 | 24th March 2008 08:36 PM |
| It is BASIC or is it BABL | 3v0 | Micro Controllers | 22 | 7th May 2007 02:09 PM |
| free pic basic complier | dstich | Micro Controllers | 7 | 1st August 2006 07:13 PM |
| Assembly to Basic Coding | AZdave | Micro Controllers | 3 | 23rd January 2005 02:28 PM |
| PIC basic and Basic stamp | Cyborg | Micro Controllers | 5 | 21st April 2004 08:44 AM |
