Experienced Member
Many laser diodes have a photo-diode inside that is used with an external transistor to adjust the brightness. I don't know if these laser diodes have the feedback transistor and I don't know how much extra voltage the transistor needs.
The transistor also might limit the current. The datasheet for the laser diode assembly will tell all.
Uncle $crooge |
Experienced Member
The "manufacturer" AixiZ Service & International, LLC is just a distributor for 184 companies that make laser diodes and many other optical items.
The search on the website did not know of the part number for the laser diode.
Uncle $crooge |
Torben... thanks for all the info, it is clarifying much for me...
audioguru... yeah I was thinking that would be the case. I'm pretty sure that they're actually made somewhere in China. I couldn't find that info on their web site.... Last edited by Willie TwoFinger; 11th May 2008 at 02:36 PM. |
Experienced Member
When you buy parts from E-Bay then you don't get a datasheet and you don't get the spec's that are needed to use the parts properly.
Uncle $crooge |
Another question has come up...
"We need to find out the formula for the amps when we wire it series/parallel. Is it just straight up division? If I had lets say 200 diodes wired into four groups of 50 -and each of those four was wired series, and I used a 12 volt adapter- then would the total amps be 1/4th what it would be?" |
Also, how big of a resister can be placed on each diode if I so desired? I know that is a lot but... I'd do it... is it even feasible?
Experienced Member
OK, for this I'm going to assume we're just using bare LEDs here (not laser modules with integrated electronics). Assumptions: all LEDs are 3.2V LEDs which want 50mA; we have a 12V power supply. So Vled = 3.2V; Iled = 50mA, and Vsupply = 12V. The short answer to your questions is "No, the total current drawn would not be 1/4 of of just wiring them all up in parallel. It would be 0." That is, 200 3.2V LEDs wired in 4 strings of 50 LEDs each would not even try to light up from a 12V power supply. Remember that you need (Vled * number of LEDs per string) volts to run the thing. (3.2 * 50) = 160V. You are not going to get a 160V device to run on a 12V power supply without some kind of boost converter. If you used a 160V+ power supply then the current draw would be 200mA (50mA * 4). With a 12-volt supply your longest string of LEDs can be 3 LEDs long. Why? Because 3.2V goes into 12 at most 3 times. So you could do 66 groups of 3 LEDs (with 2 LEDs left over), or 100 groups of 2 LEDs. Make sense? Torben |
Torben...
Yeah, it's starting to sink in... Much thanks! |
Experienced Member
Everybody is just guessing without detailed spec's.
The laser assemblies might need external current-limiting or not. What is their minimum and maximum allowed voltage and current?
Uncle $crooge |
| Visual Basic for Electronics Engineering Applications | ThermalRunaway | Electronic Books | 20 | 10th July 2008 07:58 PM |
| It is BASIC or is it BABL | 3v0 | Micro Controllers | 22 | 7th May 2007 02:08 PM |
| free pic basic complier | dstich | Micro Controllers | 7 | 1st August 2006 07:13 PM |
| Assembly to Basic Coding | AZdave | Micro Controllers | 3 | 23rd January 2005 02:27 PM |
| PIC basic and Basic stamp | Cyborg | Micro Controllers | 5 | 21st April 2004 08:44 AM |
