| Electronic Projects Design/Ideas/Reviews Are you building an electronic project or want to? Maybe you need some assistance? Come and submit your electronic questions here and let our exprienced members find a solution. |
| | Thread Tools | Search this Thread | Display Modes |
| Experienced Member | Well knowing absolutely nothing about your application, since you provided no details, I will assume that you just have rotating a disk and will propose the easiest thing for it and suggest dumping the PIC. http://www-s.ti.com/sc/psheets/slus369/slus369.pdf At the end of the sheet, figure 15, shows controller logic that would even work for the line followers everyone seems to love. Add a clock, and a little logic with optical sensor to drive the direction pin and you have steering control for a stepper. If you want it to stop just stop the clock. A lot can be accomplished with simple means and no programming. An single ST driver chip instead the two TI ones along with a little logic will accomplish a lot. A different type of follower would be two wheels driven by steppers and simply slow one of the wheels to turn. The simplicity is wonderful and makes it much easier for anyone not interested in programming. |
| Using Oscilloscopes | mechie | Electronic Theory | 9 | 29th November 2007 09:49 PM |
| Setting stepper motor to 'home' position. | MrNobody | Micro Controllers | 14 | 3rd October 2007 03:04 PM |
| sensing a wooden block's position | arod | Robotics Chat | 5 | 13th September 2007 12:21 AM |
| Motor Position Control Problem | YAN-1 | Electronic Projects Design/Ideas/Reviews | 10 | 31st March 2006 02:03 PM |
| Position Sensing in 2D | Screndib | Electronic Projects Design/Ideas/Reviews | 9 | 19th October 2004 09:39 AM |
