| Electronic Projects Design/Ideas/Reviews Are you building an electronic project or want to? Maybe you need some assistance? Come and submit your electronic questions here and let our exprienced members find a solution. |
| | #1 (permalink) |
| New Member Join Date: May 2008
| I need to build a pulse counter with a PIC,employing TIMER0, with the following characteristics : 1) a square wave (0V - 4.7V) amplitude is applied to a unique pin of the PIC (say A4); 2) its frequency varies between 100Hz and 1kHz, (100,200,300,400,...900,1000); 3) the output is given in binary with leds (8 bits) and remains in the configuration during the application of the signal; 4) when the signal is switched off, the leds of the configuration become off; |
| | #2 (permalink) |
| Experienced Member Join Date: Oct 2006 Location: Australia
| Do you need to employ TMR0? This can be easily done by incrementing registers eg, Code: Repeat Until PORT.Pin = 0 Repeat Until PORT.Pin = 1 Repeat Inc(Result) Until PORT.Pin = 0 Code: Result = 0 Repeat Inc(Result) Until PORT.Pin = 0 or Result = 0 Result = 0 Repeat Inc(Result) Until PORT.Pin = 0 or Result = 1 Result = 0 Repeat Inc(Result) Until PORT.Pin = 0 or Result = 0
__________________ Spency. How many PC programs are developed with assembler? Then why use it with PIC's? PIC's and interfacing with other devices - a PIC Basic Guide @ digital-diy.net |
| | #3 (permalink) |
| Experienced Member Join Date: Oct 2006 Location: Colombo
| Ya 100 to 250 of course ok & when the pulse increase you need to do some multiplication routine (8bit mul) will be fine.Aaaah you are displaying it on 8 LEDs. I use TMR0 as counter & feeding pulse to RA4 something like that & reads the TMR0 value on certain period of time & do all other calculations. But for example if the frequency is 300Hz how do you show them from 8 LED's?
__________________ Gayan Forum Supporter |
| | #5 (permalink) |
| Thanks for your reply. I would appreciate if you could give-me the source code (in MikroC or CCS C) for a pulse counter with the TIMER0, counting frequencies from, say, 10Hz up to 200Hz, with ranges of 10Hz (10,20,30,.....200) with bynary outputs in 8 leds. Best regards and thanks for cortesy. EDSON |
| | #6 (permalink) | |
| Experienced Member | Quote:
| | #7 (permalink) | |
I don't do C
__________________ Spency. How many PC programs are developed with assembler? Then why use it with PIC's? PIC's and interfacing with other devices - a PIC Basic Guide @ digital-diy.net | |
| Problem measuring pulse width - 12F683 TMR1, 8MHz | jess | Micro Controllers | 18 | 5th February 2007 10:00 AM |
| How we can do it in Assembly..Help Needed | Ayne | Micro Controllers | 37 | 29th December 2006 05:49 PM |
| measure pulse width with a counter...other ways?? | xmat | Electronic Projects Design/Ideas/Reviews | 7 | 6th April 2005 08:05 AM |
| Pulse Width Calculation | waqar | Micro Controllers | 1 | 25th June 2003 11:54 AM |
| using 8051 as pulse counter | waqar | Electronic Projects Design/Ideas/Reviews | 0 | 13th March 2003 04:06 PM |
