| Electronic Projects Design/Ideas/Reviews Are you building an electronic project or want to? Maybe you need some assistance? Come and submit your electronic questions here and let our exprienced members find a solution. |
| | Thread Tools | Search this Thread | Display Modes |
| Experienced Member | Quote:
Look here: http://www.kmitl.ac.th/~kswichit%20/...neinverter.pdf
__________________ Eric "Good enough is Perfect" PIC tutorials: Nigel's site: http://www.winpicprog.co.uk/ Gramo's site: http://www.digital-diy.net/ | |
__________________ Superman Returns.. http://www.supermanhomepage.com/imag...an-returns.gif My friend created this account for me.. LOL http://bananasiong.myminicity.com oh.. somemore http://bananasiong.myminicity.com/env Exam T_T.T | |
| New Member | Hi there Guys The sizes I'm looking for is 12VDC 500W, 24VDC 1500w, 24/48VDC 3000W and, if possible, 48VDC 5000W. This will give me a great product range. I can even build my own deep cycle batteries for starters and already designed charge controllers using the LM338T's. Now its just a matter of getting the schematics for the TSW's and MONEY for the components. Once again - THANKS GUYS!!! You do give me hope for my future. Best Regards from a cold South Africa! Deon |
| New Member | Quote:
It is actually very easy. First obtain acid proof containers that can seal(for leakage and sealing in hydrogen gas). Next will be a pot or cauldron to melt lead in. Then a mold in which to cast the lead plates(aluminum works best, because the hot lead don't stick to it). Then you have to see a steel profile cutter(luckily a friend of mine is our local cutter) and manufacture plate bridges to link the lead plates together and mount your terminals on(Stainless Steel of any grade will do, aswell for the terminal bolts welded onto the bridges). Between the lead plates(in a +-+-+- array), you will need to place an acid proof barrier material like fibreglass matting. Drill holes for the terminals and a breather hole for the H2 gas and fit a pipe to let the gas escape to a well ventilated area. After that, place your linked,barriered lead plates into your container, fill the container so that the plates are covered with acid and seal of. Now test the Ah(amp hour) rating by putting a 1A load on the battery till it reaches 80% of the original startup voltage. A newly build cell sould read 2.12V. Time how long the battery takes to reach the 80% capacity level and that should give you your Ah rating x6 for a 12V system, x12 for 24V and 2x24 for 48V. Hope it help. Kind regards Deon Ps: A gas mask, Safety Goggles and leather coveralls should be worn when handling the lead and gas mask, safety goggles, acid proof coveralls and rubber gloves should be warn when working with the acid | |
| Prue Sine wave 3000 watt RMS inverter | pwd666 | Electronic Projects Design/Ideas/Reviews | 5 | 30th March 2008 03:17 PM |
| sine wave to square wave | jay543_uk | Micro Controllers | 17 | 1st February 2008 06:24 PM |
| sine wave to triangle wave | raviram87 | Electronic Projects Design/Ideas/Reviews | 5 | 12th January 2008 05:01 AM |
| turn old UPS into a Sine Wave Inverter | simoin | Electronic Projects Design/Ideas/Reviews | 27 | 21st November 2006 02:02 PM |
| square wave to sine wave | tony Ben | Electronic Projects Design/Ideas/Reviews | 2 | 26th January 2005 04:05 AM |
