Electronic Projects Design/Ideas/Reviews Are you building an electronic project or want to? Maybe you need some assistance? Come and submit your electronic questions here and let our exprienced members find a solution.
Thread Tools Search this Thread Display Modes
Old 8th May 2008, 06:09 AM
matthua is on a distinguished road
Default Need help with a motor project of mine...
Hello everyone.... I am not too familiar with the electronic field though I am great at following instructions and assemble working circuits. Therefore, I'm hoping that one of you will be able to assist me.
I am looking for a component(s) that will operate a 12 V motor under all the options below.
When Switch is in position #1, motor will turn off.
When Switch is in position #2, motor will turn on for 10 minutes when it senses motion and then turns off after ten minutes.
When Switch is in position #3, motor will turn on for 10 minutes and then turns off. Motor will repeat this again every 2 hours.
When Switch is in position #4, motor will turn on for 20 minutes and then turns off. Motor will repeat this again every 2 hours.
When Switch is in position #5, motor will turn on for 30 minutes and then turns off. Motor will repeat this again every 2 hours.
All these will be powered by two AA batteries.
I hope I am not being too general in my description. Please let me know if you need any other pertinent information.
It would be great if you can provide me with the appropriate parts name and number that I need to purchase to make my project possible.
Thanks ahead for your time and input....
matthua is offline   Reply With Quote
Old 8th May 2008, 07:46 AM
Experienced Member
Torben is a glorious beacon of lightTorben is a glorious beacon of lightTorben is a glorious beacon of lightTorben is a glorious beacon of lightTorben is a glorious beacon of light
You want to run a 12V motor from 3V? Or does the motor have its own power supply?
Torben
Torben is online now   Reply With Quote
Old 8th May 2008, 04:18 PM
Thanks for the quick response Torben. Motor does not have its own power supply. I'm hoping to power it using only AA batteries... either two or four of them depending on how long they will last before they died out.
Old 8th May 2008, 05:19 PM
Experienced Member
mneary is just really nicemneary is just really nicemneary is just really nicemneary is just really nice
Send a message via AIM to mneary
Can you describe the 12V motors? How much current do they require to run? to start?
mneary is offline   Reply With Quote
Old 9th May 2008, 05:28 AM
It's for fan. You know... the one inside a pc tower... I just looked at the specs and it says 12V DC (0.14A). Thanks for getting back to me. Let me know if you need any other info.
Old 9th May 2008, 11:05 AM
Experienced Member
Gayan Soyza is just really niceGayan Soyza is just really niceGayan Soyza is just really nice
For that brush less motor I used IRFZ 24N mosfet to control their speed.
In you case the 2 hour time period is same in all occasions.Need to do the off time after pre determine time.
Adding couple of 555 IC's will help you.One IC to select the on time (Ex:10,20,30 mins) & the other IC to start the 2 hour time period after getting the off signal from the 1st IC.
Sorry its just an idea & never worked on that.
The sense part I cannot understand.Unless it has some tacho output fan (3 pin fan) to calculate the RPM.
Gayan
Forum Supporter
Gayan Soyza is online now   Reply With Quote
Search this Thread:
Advanced Search
mine detector circuit pls sharmilee Electronic Projects Design/Ideas/Reviews 5 28th August 2006 10:51 PM
A small gold mine in the trash! HiTech General Electronics Chat 21 17th July 2006 12:05 PM
Anyone need ICD2 clone info?Here's mine. Alex_rcpilot Micro Controllers 2 15th February 2006 06:01 PM
PCB photo-resist exposure times? Mine won't develop! HandyMan Electronic Projects Design/Ideas/Reviews 8 22nd February 2005 04:18 PM
Desperate.. need file p12c508.inc mine are missing...! loco_g Micro Controllers 5 13th September 2003 08:16 AM
Powered by vBulletin Version 3.5.4
Search Engine Friendly URLs by vBSEO 2.4.0
