Experienced Member
i need to implement a circuit that inputs two 4bit numbers (y3 y2 y1 y0 x3 x2 x1 x0)
and it has an output of (c3 c2 c1 c0 s3 s2 s1 s0) where "c" is the carry and "s" is the sum i was given an example in which X=0101 (5) Y=1000 (8) and it outputs S=1010 (10) and C=0011 (3) 5+8=13 i dont know what is the role of C and S how do they split the numbers??? i was asked to implement it using two 4 bit adders here is the answer: http://s290.photobucket.com/albums/ll279/t...nt=IMG_8831.jpg i cant understand this circuit ???????? |
Experienced Member
Consider each bit individually. For each bit there are 3 inputs (X,Y,Ci) and 2 outputs (S,Co). The carry gets carried to the next significant bit, Carry Out (Co) becomes Carry In (Ci) for the next digit.
You example is wrong. X=0101(5) + Y=1000(8) = S=1101(13) and C=0000 A better example is X=0111(7) + Y=0110(6) = S=1101(13) and C=0110 To get the next digit of the answer you add the X and Y bits and the carry bit from the previous bit addition. Adding 2 bits can result in an answer from 00 to 11(3) - the left bit is the carry the right is the output. Mike. |
Experienced Member
how can you explain that
S binary column is bigger by 6 then DEC number and when the DEC number goes bigger then 10 then it has "1" and a normal number the dec number is supposed to equal to the binay noy to be smaller by 6 ??? and in the EX3 column we each number is bigger by 3 then DEC number and when the DEC number is smaller then 10 we dont have another 4 bits ????????? |
Experienced Member
I don't understand what you are saying, 7+6=13 or 0111+0110=1101.
The carry is just a record of where a carry took place. Think of, 123+389 = 512 and the carries are 011. I.E 3+9 = 12 = 2 + carry, 8+2+C = 11 = 1 + carry, 1+3+C = 5. Mike. |
Experienced Member
i understood you
but its about the sum of two EX3 number and a output of two numbers one represents the number of "tens" and the other represents the "ones" there is a table in the link i was given http://s290.photobucket.com/albums/l...t=IMG_8831.jpg S binary column is bigger by 6 then DEC number and when the DEC number goes bigger then 10 then it has "1" and a normal number the dec number is supposed to equal to the binay not to be smaller by 6 ??? and in the EX3 column we each number is bigger by 3 then DEC number and when the DEC number is smaller then 10 we dont have another 4 bits ????????? |
| Building a circuit to sum voltage per unit time? | omgwtfbyobbq | Electronic Projects Design/Ideas/Reviews | 5 | 8th April 2008 11:24 PM |
| Best motor for grabbing mechanism | Klitzie | Robotics Chat | 3 | 8th February 2008 02:50 PM |
| need an idea on making a counter with a restart mechanism | dark_conqueror | Electronic Projects Design/Ideas/Reviews | 0 | 26th November 2003 04:25 AM |
| Digital clock setting mechanism | patroclus | Electronic Projects Design/Ideas/Reviews | 6 | 17th November 2003 12:37 PM |
