Electronic Projects Design/Ideas/Reviews Are you building an electronic project or want to? Maybe you need some assistance? Come and submit your electronic questions here and let our exprienced members find a solution.
Thread Tools Search this Thread Display Modes
Old 7th May 2008, 02:27 PM
Experienced Member
MrDEB can only hope to improve
Default led multiplexing dim or ??
been getting some input from audioguru about multiplexing a 10 x 10 led matrix.
The issue of leds being to dim was discussed at length.
After finding this circuit I wonder if dim leds is an issue??
the planned circuit is attached (only one led of planned display is attached.
found another circuit that uses 2n3904 at both ends of the leds with one end having a 10K resistor connected to the base and a 300 ohm resistor connected to the collector.
Will try and locate circuit
Any advice??
http://www.best-microcontroller-proj...x-display.html
MrDEB is offline   Reply With Quote
Old 7th May 2008, 03:17 PM
Experienced Member
blueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to behold
Send a message via Skype™ to blueroomelectronics
Not sure I understand how a pair of 4017 Johnson counters display anything useful. The original circut uses a PIC with a parallel output. The 4017 works fine as a column driver I use a Johnson counter CD4022 in my Dragonfly schematic to drive seven segment LEDs.
The schematic on the left each LED get 23mA which is fine, should be nice and bright.
Since you're building a spectrum analyzer why not just use ten LM3916's no muxing nessary.
Bill
Smart Kits build Smart People
Old 7th May 2008, 11:10 PM
Experienced Member
audioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to behold
The link has a PIC with a 0.2V voltage loss when its output currents are a few mA.
The ULN2003 darlington driver has a loss of about 0.7V.
Red LEDs have a loss of 1.8V.
So the total losses are 2.7V and the 470 ohm current-limiting resistors create a current of 4.9mA which is not bright.
I can't see why your circuit is wired so oddly.
The display is multiplexed among 8 columns so each lighted LED has an average current of 4.9mA/8= 0.6mA which is very dim.
Maybe your LEDs look OK when they are very dim.
Bill Bowden's circuit on the left has pulses of 21mA in its LEDs. The 21mA is divided into 5 columns so each lighted LED has an average current of 4mA which is not bright and is not dim.
Old 8th May 2008, 12:52 AM
Experienced Member
Why do the ExpressSCH schematics look terrible? Is there no snap function?
Bill
Old 8th May 2008, 02:40 AM
Experienced Member
Default I havn't fine tuned the schematic
I kinda tried some other pc board prgs but big learning curve.
This may sound dumb but why are we dividing the current by number of rows?
I thought each row comes on seperatly? The lm3916 controls the colums and the 4017 controls the rows or vice versa.
I am kinda lost or ??
AFTER LOOKING at the multi plexed display using a pic I see no difference between a pic and an lm3916 as far as sinking current?? Of coarse putting a transistor at both ends.
Lost in Salmon, Idaho
Old 8th May 2008, 04:00 AM
Experienced Member
An LED that has continuous 20mA current looks bright.
Multiplexing turns on one column at a time. So if there are 10 columns then an LED in one column is turned on for only 1/10th of the total time.
Your vision is slow and sees only the average amount of current which is 1/10th the continuous amount so the LED looks very dim.
Old 8th May 2008, 06:45 AM
Experienced Member
ericgibbs is a splendid one to beholdericgibbs is a splendid one to beholdericgibbs is a splendid one to beholdericgibbs is a splendid one to beholdericgibbs is a splendid one to beholdericgibbs is a splendid one to beholdericgibbs is a splendid one to behold
hi Bill,
It looks like he has the Snap ON, he just isn't taking care in placing the end of the wires.. that why its looks a mess.
MrDEB,
Try to arrange the circuit drawing layout so that it 'flows' from left to right across the paper, it makes it a lot easier to read, so you will get better forum feedback...
Also switch the 'grid' OFF, using the Options menu before you screen capture.
I know these points might sound picky, but a better presentation will get a better response..
If you build the 2 * 4017 [x,y] LED scanner, how do you plan to change the 'pattern' being displayed.?
Eric
"Good enough is Perfect"
PIC tutorials:
Nigel's site: http://www.winpicprog.co.uk/
Gramo's site: http://www.digital-diy.net/
Old 8th May 2008, 01:04 PM
Experienced Member
Default The lm3916 should take care of it
This circuit is using the design of the Oriental circuit as its being called.
http://www.electro-tech-online.com/a...f?d=1193058218
On circuit drawings you mentioned SNAP ON. should I have it on or off? I need to check which I have set.
Old 8th May 2008, 10:41 PM
Experienced Member
The PDF you posted looks pretty good, why not just build it exactly as in the PDF? Why bother trying to redesign it?
If you want to get better with any bit o software, practice, practice, practice. Try drawing something simple. Make it look like other schematics on the site. Try to draw something simple.
Bill
Old 9th May 2008, 02:06 AM
Experienced Member
Default The leds may be to dim
we are building a stereo EQ unit. So 2 displays are being built.
The leds being onm only 1/10 of a second would possiably be dim.
Audioguru is recommending hitting the leds with what ever the max pulse current is. I believe in this case the pulse current is 50ma (need to recheck the data sheet)
What we may do, seeing how we have several different colored smd leds , we may insert a pot in series with each row of the matrix. then adjust the brightness accordinally. Still have a resistor in series so as not to pop any leds.
Wanting to use same circuit for the audio out to an amp but with all the switching of the matrix, it may introduce tooo much noise. A TILT circuit may be implemented. Not sure.
This is a project that one of my Boy Scouts wants to build. I am just along for the ride so to speak.
Old 9th May 2008, 01:16 PM
Experienced Member
The LEDs must be multiplexed much faster than 1 second for all 10 columns.
You don't want each lighted LED to flicker so multiplex them at 100Hz or faster.
Old 10th May 2008, 01:55 PM
Experienced Member
Default Thanks now just need to compute
proper transistor biasing etc.
Sure wish the unit could be used to pass the audio from input through the filters/multiplexing display then out.
would the quad bi lateral switches be quieter that the transistors used in the multiplexing. or ??
just wondering.???
Old 10th May 2008, 02:49 PM
Experienced Member
I still don't understand why you just don't build a non multiplexed version. Or at least the version in the PDF you posted.
Bill
Old 10th May 2008, 03:03 PM
Experienced Member
Hi MrDEB,
I notice a 1uF capacitor to ground at the output of the filter opamp. Then the opamp won't work, it will oscillate instead.
The capacitor is probably part of a peak detector circuit at the output of each filter opamp. The 1uF capacitor should be at the collector of the switching transistor.
Old 10th May 2008, 03:28 PM
Experienced Member
Default Oups!!!!
Took another look at the oriental circuit--boy are you sharp.
I put the cap on wrong sife of diode.
Maybe I will get this thing built (Chris I mean) I need to order some parts so we can finish the pocket unit.
I looked at the circuit board he has assembled and Think he installed the wrong caps (TILT). I see mostly cermic ones instead of poly caps.
As I said before we may just input the audio in parrell (the eq display and a TILT unit but use dip ic's instead of the surface mount.
got to go.
THANKS for all your input
Search this Thread:
Advanced Search
24V Flip Flop Help Required LeeH68 Electronic Projects Design/Ideas/Reviews 38 10th April 2008 07:01 PM
230 Volts LED night light project RODALCO Electronic Projects Design/Ideas/Reviews 12 2nd March 2008 11:43 PM
need help... imisendo_4036 Micro Controllers 0 20th February 2008 01:15 AM
LED Matrix Project Debug, Please Help :[ mekohler Micro Controllers 2 7th December 2007 06:57 AM
P channel FETs vs N channel FETs for LED Matrix applications ?? tdg8934 General Electronics Chat 3 9th September 2007 05:17 PM
Powered by vBulletin Version 3.5.4
Search Engine Friendly URLs by vBSEO 2.4.0
