+ Reply to Thread
Results 1 to 9 of 9
Thread: 12 volt battery monitor that will switch a relay off
  1. #1
    ron roberts Newbie
    Join Date
    Nov 2007
    Posts
    13
    Default 12 volt battery monitor that will switch a relay off
    Hi everyone can anyone help.
    I have a small 12 volt bulb that I need to run from a 12 lead-acid battery but when the battery goes under 10 volt I would like some kind of circuitry that will switch a changeover relay. This relay will need to disconnect the bulb and switch my solar panel charger to recharge the battery. Now when the battery is charged fully I need the circuitry to switch back to running the bulb and disconnect the solar panel.
    So in short I need a 12 volt battery monitor that will switch a relay off when the voltage goes below 10 volt and back on again when the voltage risers above 12 volts.
    i know i need a voltage comparator and a current comparator. They set and reset a flip-flop circuit.
    The outputs of the flip-flop drive Mosfets that connect the solar panel and disconnect the light bulb.
    but i need a diagram only please
    can anyone help
  2. #2
    ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent
    Join Date
    Jan 2007
    Location
    Hampshire. England.
    Posts
    10,849
    Blog Entries
    13
    Get the datasheet for the LM393 www.datasheetarchive.com
    You require the 'limit' circuit.
    Modify the circuit to drive the relay.
    Do you follow.?
    Link to my Articles: http://www.electro-tech-online.com/a...icgibbs-55450/
  3. #3
    rjvh Excellent rjvh Excellent rjvh Excellent rjvh Excellent rjvh Excellent
    Join Date
    Dec 2007
    Location
    cambodia
    Posts
    865
    i build this circuit more than a dozen time
    simple, effective and cheap
    sucsess
    Robert-Jan
  4. #4
    ron roberts Newbie
    Join Date
    Nov 2007
    Posts
    13
    Hi rjvh thanks for the diagram it looks interesting but it seems to be in German. The diagram its self is no problem but you say you have built them, so I was just wondering if you can tell me a bit about its performance. How adjustable is it. When it switchers off, will it switch back on a gain when the battery is charged sufficiently. And so on.
  5. #5
    ron roberts Newbie
    Join Date
    Nov 2007
    Posts
    13
    Hi ericgibbs
    thanks for the diagram looking in to that one many thanks.
  6. #6
    Join Date
    Jan 2007
    Location
    Hampshire. England.
    Posts
    10,849
    Blog Entries
    13
    Quote Originally Posted by ron roberts
    Hi ericgibbs
    hi Ron,
    Look at this link:
    http://www.national.com/mpf/LM/LM723.html
    Get the 723 datasheet.
    Its the ic used in Robert-Jan circuit.
  7. #7
    Join Date
    Dec 2007
    Location
    cambodia
    Posts
    865
    Hi Ron Roberts
    the text is dutch not german but still not a world language so i don't blame you that you couldn't read it
    it switch off at a level around 11.2 volt but this is adjustable
    the 47khm: resistor gives hysterisis in the circuit so it means that the voltage has to rise a bit more (+/- 1 volt) to switch back on
    if you play a bit with this resistor you can narow or wyden the band of swiching suitable for your aplication
    if you change the resister values at the inputes of the comparator you can change the initial switching points up to the value that is suitable for you
    Sucsess with building it
    Robert-Jan
  8. #8
    jtexas Newbie
    Join Date
    Jun 2007
    Location
    DFW
    Posts
    15
    Note that discharging a 12-volt lead acid battery below 10.8 volts can damage the battery.
    Unless your battery is labelled "deep cycle", repeated discharges beyond 50% (12.23 volts at 70ºF/21.1ºC) will seriously shorten its useful life. For best results limit the depth of discharge to 20% (12.48 volts), and if at all possible avoid discharges of more than 80% (12.02 volts).
    A deepcycle battery performs best when the average depth of discharge is between 20% and 90% (11.95 volts).
    A wet cell battery with a 20% average depth of discharge can last up to 5 times longer than the same battery with a 50% average DoD.
    The battery is fully charged at 12.64 volts.
  9. #9
    ron roberts Newbie
    Join Date
    Nov 2007
    Posts
    13
    Thank you all. Still working on it but it looks like I have all the answers on this forum. Thanks
+ Reply to Thread
  1. Delay switch / relay
    By mbeaver in forum General Electronics Chat
    Latest: 19th March 2008, 05:52 PM
  2. Simple Battery Power switch with diode?
    By dbtoutfit in forum Electronic Projects Design/Ideas/Reviews
    Latest: 5th February 2008, 09:45 AM
  3. Please help me in writing code
    By abdosat2000 in forum Micro Controllers
    Latest: 5th June 2007, 01:41 PM
  4. Looking for pre-built 12 volt momentary latching relay
    By Louis Cypher in forum General Electronics Chat
    Latest: 2nd December 2006, 07:31 PM
  5. Defeating a Dimmer Switch
    By mikeb in forum Electronic Projects Design/Ideas/Reviews
    Latest: 3rd August 2006, 01:38 PM
Tags for this Thread
