Hi everyone,
I need to build a circuit that could measure a buttery charge, and I want to use three Leds that would be on (as the princible of mobile buttery charge), if the buttery is weak one led will flash ,if it's little bit stronger two will flash and if it's stronger(as full) three leds will be on . I hope you got the idea , the three leds would be in series. Would this circuit be usfull to measure a car buttery if impelmented? Thanks |
Yes, but it would only properly montor the battery charge after setting for awhile with the engine off and no battery load. It would not work when the engine is running and charging the battery. Also it takes several minutes after charging stops before the battery stabilizes to its final voltage to determine its state of charge.
Ok, but first what would the circuit look like? Have you got any information or usfull sites?
Thanks |
Nobody said if the battery is lead-acid, Ni-Cad, Ni-MH or lithium-poly.
Their voltage vs amount of charge are all different.
Uncle $crooge |
Lefty
Measurement changes behavior |
Lithium Iron Phosphates are pretty flat as well... And stable to boot!
But if his inquiry was for batteries in general then, as you noted, a voltage measurement by itself will not necessarily work. |
seems you need corrective lenses when reading. I never heard that cars are equipped with Ni-Cads, Ni-MH or lithium-poly batteries. Hans |
Ni-Cads are old and toxic. Many battery manufacturers don't make them anymore.
Most car manufacturers use Ni-MH cells in their hybrid cars and the car's computer knows the exact amount of charge. The driver does not need to know. I have seen tiny cars called SMART. Maybe they use rubber bands or a Li-Po battery for power. Lead-acid batteries in cars are charged by the alternator so there is no reason to know the state of charge.
Uncle $crooge |
Ahhhh...could I get some of that buttery charge for my popcorn?
We never have time to do it right; but we always have time to do it over. |
They are the non-plus-ultra cars for shopping. Easy to park (you can park three SMARTs on the same parking lot you are parking your car.) |
Try this.
In the circuit below, a quad voltage comparator (LM339) is used as a simple bar graph meter to indicate the charge condition of a 12 volt, lead acid battery. A 5 volt reference voltage is connected to each of the (+) inputs of the four comparators and the (-) inputs are connected to successive points along a voltage divider. The LEDs will illuminate when the voltage at the negative (-) input exceeds the reference voltage. Calibration can be done by adjusting the 2K potentiometer so that all four LEDs illuminate when the battery voltage is 12.7 volts, indicating full charge with no load on the battery. At 11.7 volts, the LEDs should be off indicating a dead battery. Each LED represents an approximate 25% change in charge condition or 300 millivolts, so that 3 LEDs indicate 75%, 2 LEDs indicate 50%, etc. The actual voltages will depend on temperature conditions and battery type, wet cell, gel cell etc. Last edited by Gayan Soyza; 7th May 2008 at 05:30 AM. |
SMART:
SwatchMercedesart 3 cyl. 599ccm, 61DIN-HP, max. speed 135km/h (85mph) Last edited by Boncuk; 7th July 2008 at 11:48 PM. |
| Discrete Pulse width Modulator... | Rajagopal87 | General Electronics Chat | 8 | 16th August 2006 05:25 AM |
| delay circuit? | aerial | Electronic Projects Design/Ideas/Reviews | 3 | 11th August 2006 05:29 PM |
| how can i make a board myself? | vasanthakumar | General Electronics Chat | 6 | 9th August 2006 04:33 PM |
| Activating a circuit using a photocell | mtrails | Electronic Projects Design/Ideas/Reviews | 5 | 10th May 2006 05:13 AM |
| info on how to make your own circuit boards needed | Richie086 | General Electronics Chat | 2 | 2nd May 2003 01:10 PM |
