+ Reply to Thread
Results 1 to 7 of 7
Thread: power amplifier
  1. #1
    faust Newbie
    Join Date
    May 2008
    Posts
    2
    Default power amplifier
    Hello!I am at the begining in constructing..i would like to make a power ampl.
    with this specifications:
    Vin 10mV/600Ω, 20W/ 8Ω, class Α , frequency 100-10000Hz.
    If you could help it would be great.. Thanks for ur time!
  2. #2
    Leftyretro Excellent Leftyretro Excellent Leftyretro Excellent Leftyretro Excellent
    Join Date
    Mar 2007
    Location
    Hercules, California
    Posts
    1,420
    Quote Originally Posted by faust
    20 watts rms using class A is going to be expensive and generate lots of heat. A modern class A/B amp of the same power rating would be much more practical and you will not be able to hear a diffence in sound if your honest.
    Larry
    Measurement changes behavior
  3. #3
    mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,831
    Here's a website where they seem to be fascinated with class A.
    http://www.passdiy.com/amps.htm
  4. #4
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,870
    A bandwidth of only 100Hz to 10kHz is almost as lousy as an AM radio.
    No bass and no sizzling highs.
  5. #5
    da costa lima Newbie
    Join Date
    May 2008
    Posts
    1
    Exclamation Relay Timer Response
    Hi guys i need to build a simple circiut that can show switching response time in the relays that has got base timers in them ,and also check all contacts of the relay and its coil for funtionality.
  6. #6
    faust Newbie
    Join Date
    May 2008
    Posts
    2
    Thanks everyone for the answers that gave me,but the problem with that circuit is that is a projekt that i have..so i must stick woth the characterisitcs that that they have gave me..
  7. #7
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,870
    What circuits are needed for the specified amplifier:
    1) 600 ohm input impedance.
    2) Enough voltage gain so that 10mV input produces 20W output into 8 ohms.
    3) Class-A.
    4) Attenuate frequencies below 100Hz.
    5) Attenuate frequencies above 10kHz.
    6) A power supply for it.
    7) Cooling for it.
+ Reply to Thread
  1. 20 Watt Power Amplifier
    By ElectroMaster in forum Electronic Projects
    Latest: 22nd January 2009, 01:16 AM
  2. power amplifier help
    By monkeytree in forum Electronic Projects Design/Ideas/Reviews
    Latest: 27th March 2005, 03:04 PM
  3. Hitachi MOSFET for power amplifier
    By erajoma in forum Datasheet/Parts Requests
    Latest: 21st February 2005, 02:50 AM
  4. Best Precision, Low Power JFET Amplifier on the Market
    By TheOne in forum General Electronics Chat
    Latest: 30th January 2005, 04:28 AM
  5. RF Power Amplifier
    By julio in forum Electronic Projects Design/Ideas/Reviews
    Latest: 6th August 2003, 08:32 PM
Tags for this Thread
