| New Member | Hello, I want to build a tool to cut light-weight vinyl with heat. I cut vinyl all day and scissors go dull very quickly. I would like to have something like an electric (Heat) rope cutter at home depot. I need to have this device battery operated (6v or 12v) as A.C. power is not practical. I need the cutter to turn on via a push button and turn off when released. Total run time will be about 15 - 20 seconds per cut. I suppose my biggest question to the forum is: How can I regulate the D.C. current to heat the wire? Thanks |
| Experienced Member | Quote:
A high current voltage regulator might be what you need to get the correct temperature on your wire. Another alternative is to get a pair of tungsten carbide scissors. | |
| Experienced Member | There are a variety of portable soldering irons. Some use a fuel gas; others use electricity. I have attached images of two electric versions. The larger (Sears) unit is mains powered and is just like the one I use for cutting plastics. I use a piece of heavy wire for my cutter that has been flattened in the center to cut plastics. The problem, of course, with a portable unit is that battery capacity is not adequate for extended cuts. If I needed longer cuts, I would use a cutter based on fuel gas. As for current/temperature regulation, there is some regulation from the source with AC powered cutters; however, most of the regulation comes from the user and how fast you move the wire. I would just find a wire of suitable resistance and make fine adjustments with the speed of cut and by pulsing the on/off button. That is exactly how I control my mains-powered portable iron. John |
| IR / Thermal reader diy. | Short Cut | General Electronics Chat | 12 | 13th October 2007 02:24 AM |
| Thermal fuse ? | ClydeCrashKop | Datasheet/Parts Requests | 5 | 2nd September 2007 09:40 PM |
| PCB thermal resistance | Oznog | General Electronics Chat | 3 | 23rd July 2007 04:45 AM |
| Wire cutter | raitl | Robotics Chat | 3 | 28th January 2006 02:49 AM |
| any alternative to the spot face cutter | samcheetah | General Electronics Chat | 7 | 6th August 2004 02:42 AM |
