Old 6th May 2008, 12:29 PM   (permalink)
ElectricScott is on a distinguished road
Default D.C. thermal vinyl cutter
Hello,
I want to build a tool to cut light-weight vinyl with heat. I cut vinyl all day and scissors go dull very quickly. I would like to have something like an electric (Heat) rope cutter at home depot. I need to have this device battery operated (6v or 12v) as A.C. power is not practical. I need the cutter to turn on via a push button and turn off when released. Total run time will be about 15 - 20 seconds per cut.
I suppose my biggest question to the forum is: How can I regulate the D.C. current to heat the wire?
ElectricScott is offline   Reply With Quote
Old 6th May 2008, 01:21 PM   (permalink)
Experienced Member
Rolf is on a distinguished road
Send a message via Skype™ to Rolf
Smile Not AAA batteries ......... I Hope.
Originally Posted by ElectricScott
Hello,
I suspect it would be difficult to get a smooth cut because the melted vinyl build-up around the wire. Are you going to use automobile batteries? Because that is probably what you are going to need.
A high current voltage regulator might be what you need to get the correct temperature on your wire.
Another alternative is to get a pair of tungsten carbide scissors.
Rolf is offline   Reply With Quote
Old 6th May 2008, 07:09 PM   (permalink)
Experienced Member
jpanhalt is just really nicejpanhalt is just really nicejpanhalt is just really nicejpanhalt is just really nice
There are a variety of portable soldering irons. Some use a fuel gas; others use electricity. I have attached images of two electric versions. The larger (Sears) unit is mains powered and is just like the one I use for cutting plastics.
I use a piece of heavy wire for my cutter that has been flattened in the center to cut plastics. The problem, of course, with a portable unit is that battery capacity is not adequate for extended cuts. If I needed longer cuts, I would use a cutter based on fuel gas.
As for current/temperature regulation, there is some regulation from the source with AC powered cutters; however, most of the regulation comes from the user and how fast you move the wire. I would just find a wire of suitable resistance and make fine adjustments with the speed of cut and by pulsing the on/off button.
That is exactly how I control my mains-powered portable iron. John
jpanhalt is offline   Reply With Quote
IR / Thermal reader diy. Short Cut General Electronics Chat 12 13th October 2007 02:24 AM
Thermal fuse ? ClydeCrashKop Datasheet/Parts Requests 5 2nd September 2007 09:40 PM
PCB thermal resistance Oznog General Electronics Chat 3 23rd July 2007 04:45 AM
Wire cutter raitl Robotics Chat 3 28th January 2006 02:49 AM
any alternative to the spot face cutter samcheetah General Electronics Chat 7 6th August 2004 02:42 AM
