Electronic Projects Design/Ideas/Reviews Are you building an electronic project or want to? Maybe you need some assistance? Come and submit your electronic questions here and let our exprienced members find a solution.
Thread Tools Search this Thread Display Modes
Old 6th May 2008, 06:04 AM
unlv007 is on a distinguished road
Question pulse train generator
I want to make a simple square pulse generator producing a +5V pulse for 5ms followed by off period=20ms. How do i synthesize it using readily available ICs, transistors etc? Any ideas?
Thank you very much.
Regards
unlv007 is offline   Reply With Quote
Old 6th May 2008, 09:14 PM
Experienced Member
mneary is just really nicemneary is just really nicemneary is just really nicemneary is just really nice
Send a message via AIM to mneary
Is 5% accuracy good enough? When you say 5V, do you really mean a logic "1" for 5V logic?
Sounds like a job for a 555.
mneary is offline   Reply With Quote
Old 6th May 2008, 09:50 PM
Experienced Member
KMoffett is a jewel in the roughKMoffett is a jewel in the rough
http://home.cogeco.ca/~rpaisley4/LM555.html#4
The second or forth circuit.
Calculators are available on that site to select components for your on and off times.
Ken
KMoffett is offline   Reply With Quote
Old 7th May 2008, 05:20 AM
How do you compare 7490 and 555? I guess 555 is a classic circuit, ,but how is its performance? please let me know.
yes 5% should be good enough, the pulse train should be 5V=on and 0V=off .
So logic 1=5V.
thank you very much.
Old 7th May 2008, 05:21 AM
Thanks once again for your help
Old 7th May 2008, 02:12 PM
Experienced Member
I don't think the 7490 will give you the time periods you are looking for. Maybe a CMOS 4060 internal oscillator set to 200Hz and with a reset after the 5th count?
http://www.fairchildsemi.com/ds/CD%2FCD4060BC.pdf
Ken
Old 9th May 2008, 05:55 AM
Is it possible to build a pulse generator with controllable amplitude? The amplitude may vary from 0 to 5V? Can LM555 implement this?
Old 9th May 2008, 01:31 PM
Experienced Member
Yes...a potentiometer as a variable voltage divider, from pin 3 of the 555 to ground...voltage from wiper to ground can be varied from 0 to 5v. Simple, but with cannot drive any significant load.
Ken
Old Yesterday, 11:04 PM
If i want to increase with voltage of the pulse to 40V and be in the same timescale,that is pulse time period in ms, how should i go about it? Should i build an amplifier or should i use a new IC?
Thanks.
Search this Thread:
Advanced Search
pulse generator using NE564 hitwaterfish General Electronics Chat 13 25th March 2007 05:33 AM
Problem measuring pulse width - 12F683 TMR1, 8MHz jess Micro Controllers 18 5th February 2007 10:00 AM
Pulse Train to Sine Wave help? GregSmyth General Electronics Chat 4 17th April 2006 08:53 PM
Pulse train to DC level: kybert Electronic Projects Design/Ideas/Reviews 8 21st May 2004 08:59 PM
Digital Pulse Generator and PIC Barry Micro Controllers 7 11th March 2004 06:58 PM
Powered by vBulletin Version 3.5.4
Search Engine Friendly URLs by vBSEO 2.4.0
