+ Reply to Thread
Results 1 to 7 of 7
Thread: 100mhz oscillator circuit
  1. #1
    gray5596 Newbie
    Join Date
    May 2008
    Location
    Mid West, USA
    Posts
    6
    Default 100mhz oscillator circuit
    Greetings from a new guy. I am looking for a reasonably stable 100mhz oscillator circuit. (Any frequency from 90 to 105mhz would work well.) My application is for a portable spectrum analyzer that is driven by a YIG (and lacks a tracking generator) so at lower frequencies, it drifts a bit. I plan to use this oscillator to generate a marker signal for a reference in the FM range. Any help or alternate ideas would be appreciated.
  2. #2
    crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent
    Join Date
    Mar 2008
    Location
    USA
    Posts
    3,025
    I assume you mean megahertz not millihertz.
    Is there some reason not to use an off-the-shelf crystal oscillator module? For example, Digi-Key sells many such units with some costing only a few dollars.
  3. #3
    gray5596 Newbie
    Join Date
    May 2008
    Location
    Mid West, USA
    Posts
    6
    Sorry, I didn't proof-read my words very well. You are correct, I meant megahertz. (At 100 millahertz, I'd probably get the attention of an angry whale )
    I'm looking for something simple so the idea of a pre-made crystal oscillator sounds great. However I have a few questions. Wouldn't it be a fairly low level output? In other words, wouldn't I have to take the output from it and use it to drive a transistor to get a strong enough signal for my analyzer? Or were you thinking about driving the analyzer directly instead of transmitting the signal thru the air?
  4. #4
    Join Date
    Mar 2008
    Location
    USA
    Posts
    3,025
    Quote Originally Posted by gray5596
    I did think you would be injecting the signal directly. So this is an analyzer with an antenna input?
    One oscillator I looked at from Digi-Key (ECS-3951M/3953M-AU) has a 5V output. Attaching a short wire to the output should give a reasonable signal through the air for short distances, likely enough to be readily observed by the analyzer. Probably would also foul up FM reception at that frequency for a significant distance.
  5. #5
    Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent
    Join Date
    Nov 2007
    Location
    Phetchabun,Thailand
    Posts
    3,458
    Best bet is a TCXO. They have an initial accuracy of +/- 1ppm.
    Check at http://www.vectron.com
  6. #6
    Join Date
    Mar 2008
    Location
    USA
    Posts
    3,025
    Quote Originally Posted by Boncuk
    TCXOs are good if you need that much stability. But they are more expensive and gray5596 stated he needed a "reasonably stable" oscillator which I interpreted to mean that the stability of a standard crystal oscilllator would suffice.
    gray5596 will need to decide how much stability he needs (or wants to pay for).
  7. #7
    gray5596 Newbie
    Join Date
    May 2008
    Location
    Mid West, USA
    Posts
    6
    Thanks for the ideas, you pointed me to a much easy solution.
    I was trying to make this too hard by making it transmit thru the air, when all I had to do was take crutschow's advice and use a standard pre-made oscillator and feed this directly to the analyzer.
    I experimented with a couple of different oscillators and it worked quite well. Mission accomplished!
+ Reply to Thread
Tags for this Thread
