Old 5th May 2008, 11:08 PM   (permalink)
Experienced Member
john1 is on a distinguished road
About the refresh,
its just too easy to forget.
But thanks, and i'm sure you already know that.
John
john1 is offline   Reply With Quote
Old 5th May 2008, 11:10 PM   (permalink)
Experienced Member
i dunno quite what these springs are about,
so maybe i should draw a bit to try ...
has this spring box thing got a name?
could i find it on google ?
Old 5th May 2008, 11:12 PM   (permalink)
Experienced Member
I think that siren will only work one way round,
i spose its marked, yes ?
Old 5th May 2008, 11:18 PM   (permalink)
Experienced Member
Anonymous321 is on a distinguished road
The spring box is just a cardboard box. With holes in it. And small springs are inside it. They're just small steels springs and I decided to like crunch my wires in between the springs instead of taping my wires with duct tape.
"I think that siren will only work one way round,
i spose its marked, yes ?" I don't understand? Work one way round? Marked?
http://www.thesource.ca/estore/Produ...roduct=2730059
That is the link for my buzzer. I wrote the specifications earlier too.
And I'm going to go buy a cheap $30 digital camera. Every one I called seems to have theirs "broken". What luck. Just more stress.
But John, would you also happen to have Skype or something so we could talk as well? I dunno, it'd just be better for me to listen to what I have done wrong.
But anyway, brb with the camera.
Anonymous321 is offline   Reply With Quote
Old 5th May 2008, 11:25 PM   (permalink)
Experienced Member
crutschow is just really nicecrutschow is just really nicecrutschow is just really nice
Originally Posted by Anonymous321
crutschow -- I sort of understand what you are explaining but not really. So how am I supposed to turn the transistor on (ie. don't make the siren ring)? Supply 0.7V to it?
If I understand correctly when the transistor is off, the siren is off. To turn the transistor off you apply less that about 0.6V to the base.
To turn the transitor on requires a current into the base emitter junction (it looks like a forward biased diode). Thus the base emitter voltage will be about 0.7V when applying base current.
Does that make sense?
crutschow is online now   Reply With Quote
Old 5th May 2008, 11:33 PM   (permalink)
Experienced Member
No, Sorry,
I have no mike, i do intend to get one and fix up one of the voice systems.
But it will have to wait.
Also i think this sort of thing is best done in the open forums.
Okay, i looked at the picture of your buzzer/siren.
Yes, one lead is red, that is to indicate positive.
The chances are if you tried it the other way round, that would bust it.
Here is a little picture i have drawn.
Before you put it together with springs, are the springs spaced decently apart?
we dont want any of them touching each other.
The wire you may be using ...
is it insulated wire, which you bare the end a little way for the contact ?
Its not just lengths of bare wire is it ?
Do you reckon you could link up the siren and a transistor like that ?
If you do so it should not operate the siren yet.
John
Old 5th May 2008, 11:35 PM   (permalink)
Experienced Member
going to tend to my dinner now
be right back
Old 5th May 2008, 11:40 PM   (permalink)
Experienced Member
I'm back.
You there ... ?
Old 5th May 2008, 11:56 PM   (permalink)
Experienced Member
guessing you are 5 or 6 hours behind the time here ...
so maybe you are having dinner ?
thats Ok, i will just refresh every so often until i get fed up ...
Experienced Member
I'm back with the camera. A little more expensive than I thought but if this works in the end, it'll be worth it. Have to install some drivers rather...-_-
Insulated wire. Springs are spaced apart. I'll post a picture soon.
Old 5th May 2008, 11:58 PM   (permalink)
Experienced Member
It's 7:58pm here as I post this. What is it in Hertfordshire? But I am about to have dinner. I'll just skip it though, so no worries.
Old 6th May 2008, 12:03 AM   (permalink)
Experienced Member
Its one in the morning here,
you bought a camera just for this ?
Maybe you were getting one anyway.
Hope it wasn't too expensive.
Anyway, i would like to see this spring arrangement ..
John
Old 6th May 2008, 12:05 AM   (permalink)
Experienced Member
No, dont skip dinner.
you might fade away ...
Old 6th May 2008, 12:06 AM   (permalink)
Experienced Member
Torben is a name known to allTorben is a name known to allTorben is a name known to allTorben is a name known to allTorben is a name known to allTorben is a name known to all
Sounds like it should do the trick. Same idea as the 30-in-1 or 100-in-1 electronic lab kits sold by Radio Shack back in the day.
OK, here's a basic circuit. It's essentially the same thing that Hans (AKA Boncuk) posted earlier, except this one uses a Darlington pair instead of just one transistor.
I've drawn this one running from 9V, on the hypothesis that you have a 9V battery and not a 12V battery handy. You can either replace R3 and the LED in my circuit with your buzzer (make sure the + lead goes to V+ and the - lead goes to the collector of the Darlington pair) or just wire it parallel to LED/R3 so that you get light and sound when the beam is broken.
The buzzer should work fine at 9V; just won't be as loud as at 12V. If you want to run the thing at 12V just increase R3 to 680 ohms or so first to protect the LED. (Hm. You don't list 680 ohms in your parts list--so if you run it at 12V, try 1K for R3 and if that's too dim use 330 ohms in series with 470 ohms instead).
When I built this last night it would make a godawful howl unless I kept my cheap laser pointer aimed right at the LDR.
If you have any questions or problems lemme know. This should take about 5-10 minutes to wire together and test using your spring board.
I assume you have an LDR and a laser pointer or similar? Your original post mentioned something about running a laser on 28.5V or so. . .? Cheap laser pointers often just run off of 3 1.5V button cells in series. What kind of laser are you using?
Good luck!
Torben
Torben is offline   Reply With Quote
Old 6th May 2008, 12:14 AM   (permalink)
Experienced Member
audioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to behold
I hate seeing circuits with the batteries connected backwards.
EDIT:
I missed the last 3 pages of this thread.
Burglar alarm school project rpaus Electronic Projects Design/Ideas/Reviews 5 18th January 2007 01:11 AM
Burglar alarm madmikejt12 Chit-Chat 6 21st October 2006 11:40 AM
Adding GSM phone to burglar alarm cctv Electronic Projects Design/Ideas/Reviews 8 3rd October 2006 10:12 PM
Yet another alarm (with a laser!)... howie69 Electronic Projects Design/Ideas/Reviews 1 25th August 2006 11:05 PM
burglar alarm chriz Electronic Projects Design/Ideas/Reviews 1 21st June 2005 05:44 AM
