Electronic Projects Design/Ideas/Reviews Are you building an electronic project or want to? Maybe you need some assistance? Come and submit your electronic questions here and let our exprienced members find a solution.
Thread Tools Search this Thread Display Modes
Old 5th May 2008, 09:46 PM
Experienced Member
Anonymous321 is on a distinguished road
Hi. Well if by English you mean that I am residing in England, then the answer is no. I am in Canada (eastern time zone). I am also in school. And I have no choice but to stay up late, John; this project is due on Wednesday (2 more days from now!) and I'm a nervous wreck here b/c I can't seem to get it to work (or understand exactly what I have to do to get it to work) and my teacher is going to destroy me during presentation time. My project is on different types of detection methods in burglar alarms (i.e. PIR, ultrasonic/microwave detectors, and photoelectric beams--laser alarms). And I just decided to make a laser alarm for my model (I should've just done a trebuchet for my project!). Thank you for the help all of you, though.
crutschow -- I sort of understand what you are explaining but not really. So how am I supposed to turn the transistor on (ie. don't make the siren ring)? Supply 0.7V to it?
Torben -- May you please tell me what you mean by the 'LDR' and the 'Vcc'? And by 'pot', I guess you mean potentiometer.
But guys, I'm trying to read as much and fast as I can about these darlington transistors but I have a question: do they come premade in pairs? Or can one simply connect 2 transistors in series or something and that will work? Also, I won't be able to buy anything else most likely anymore b/c the The Source (Radio Shack in America) in my town doesn't sell electronic components anymore and I had to drive 1 hour away from here to another Source just to get the components that I have.
At school, my friend made a suggestion that I make a very basic circuit utilizing just the buzzer, the photocell, and a battery. I'll post the schematic.
I appreciate your guys' help. But like some of the things (like 555, inverters, etc.) that you guys are talking about I don't know about nor do I have access to (w/ the limited time I have and the resource being and hour drive away) and I really just want a simple design. I know the headache that I'm giving you guys and I apologize deeply. I thank you all once again for sticking with me (I hope).
Anonymous321 is offline   Reply With Quote
Old 5th May 2008, 09:49 PM
Experienced Member
Sorry, forgot to attach my friend's idea. It's in this post. Oh also, in the diagram, I wrote, "Then connect photocell to battery." I meant to write, "Then connect photocell to siren." Sorry...
Also, if you guys don't mind, maybe I can explain this better talking over skype or something and then maybe I can understand better too.
Old 5th May 2008, 09:59 PM
Experienced Member
blueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to behold
Send a message via Skype™ to blueroomelectronics
That's worse.
Bill
Smart Kits build Smart People
Old 5th May 2008, 10:06 PM
Experienced Member
Originally Posted by blueroomelectronics
That's worse.
So the use of a transistor and/or resistor is required?
My siren's specifications:
Voltage range: 3-20VDC/VCC
Rated Voltage: 12VDC/VCC
Current Consumption: 10mA max at 12 VDC/VCC
Sound Pressure Level: 76 dM min. at 11 13/16" (30cm)/12VDC/VCC
Resonant Frequency: 2,700(plus-minus symbol)500Hz
I think the only relevant ones here are the voltage rand and the current consumption...
Old 5th May 2008, 10:08 PM
Experienced Member
john1 is on a distinguished road
back soon.
that suggestion of using just the sensor is drawn incorrectly.
that arrangement could damage it.
Do you have a multimeter?
if so please describe it. thank you.
Do you have a bunch of resistors to choose one,
please describe what you have. thank you.
john1 is offline   Reply With Quote
Old 5th May 2008, 10:09 PM
Experienced Member
do you have some transistors to choose one ?
please describe, thank you.
Experienced Member
do you have a camera or webcam,
so we can see your layout, ?
John
Old 5th May 2008, 10:10 PM
Experienced Member
You have to 'Refresh' or come back to the page to see the replies.
(you may know that)
John
Old 5th May 2008, 10:13 PM
Experienced Member
Torben is a glorious beacon of lightTorben is a glorious beacon of lightTorben is a glorious beacon of lightTorben is a glorious beacon of lightTorben is a glorious beacon of light
Sorry, anon. 'LDR' means light-dependent resistor; it's just a resistor which changes value depending on the amount of light falling on it. Also referred to as 'CdS cells'.
'Vcc' is just another way of saying 'V+' or 'the positive supply voltage'.
You got the 'pot' in one.
You can get Darlingtons either as a single component (looks just like an ordinary transistor) or you can make your own with two transistors. Google 'Darlington wikipedia' for more information.
Mmm....I am away from my gear right now so I can't test that, but I have a feeling it won't work as well as you might hope.
Ah, gotcha. OK, skip the output timer. The inverter is just one transistor and a resistor configured so that the output is the inverse of the input, and a 555 is just an 8-pin timer chip which is ridiculously useful. If you just need to prove the concept of causing your buzzer to buzz, no matter how briefly, when the beam is broken, you can safely ignore the inverter/555 thing I mentioned.
What town are you in? There may be something besides The Source (even worse than Radio Shack if that is possible). Heck, in a pinch you might be able to give a local TV repairman $10 for a few bits and pieces; you never know.
Is the purpose of the exercise to show that you can design the actual circuit, or just to show that such circuits *can* be built from plans? If the latter I could just post a link or a schematic for you.
Good luck,
Torben
Torben is online now   Reply With Quote
Old 5th May 2008, 10:15 PM
Experienced Member
Are you assembling this on one of those 'breadboard' kit things,
with rows of holes that you poke the bits into ?
John
Old 5th May 2008, 10:27 PM
Experienced Member
please refresh
Old 5th May 2008, 10:33 PM
Experienced Member
Yes, I have a multimeter. It's a Mastercraft Pocket Analog Multimeter.
Specifications:
DCV...............10 V/250 V/500 V (2 K/V)
ACV...............10 V/250 V/500 V (2 K/V)
DCA...............500A/10mA/250mA
.............2K/200K (centre 3.6 K)
Yes, I also have resistors. 3 packs.
1st pack:
1/4-watt, 5% Carbon resistors, 2-pcs of each
10, 22, 33, 47, 220, 330, 470, 1k, 2.2k, 3.3k, 4.7k, 10k, 22k, 33k, 47k, 100k, 220k, 330k, 470k, 1m ohm
2nd pack:
1/4-watt, 5% Carbon resistors, 5-pcs of each
100, 220, 330, 470 ohm
3rd pack:
1/8-watt, 5% Carbon resistors, 5-pcs of each
So obviously lots of the same ones. I bought pack 1 and pack 3 b/c they were different watts. I didn't (and don't) know which one would be best.
Yes, I have transistors to choose. 2 packs.
1st pack:
On the front of the pack, it says NPN-Type Switching Transistors.
On the back:
Silicon..........NPN
Typical hFE...200
Maximum ratings
VCE.............30V
IC................800mA
Dissipation.....1.8W
Then it tells me that these are designed for high-speed, medium power switching and general purpose amplifier applications. And then it tells me which leads are the B, C, and E.
2nd pack:
On the front of the pack, it says PNP Transistors and that they're "Similar to type 2N3906".
On the back:
This 2761604 is designed as a general purpose amplifier and switch. The useful dynamic range extends to 100mA as a switch and to 100 MHz as an amplifier.
Collector-Base Voltage........60V
Collector-Emitter Voltage.....40V
Emitter-Base Voltage..........6V
Dissipation........................350MW
Then it describes which pin is the B, C, E.
And, unfortunately I do not have a camera or a webcam. My cousin has them and I suppose he may be able to lend one of them to me...What about skype?
And sorry for the late reply.
Old 5th May 2008, 10:35 PM
Experienced Member
thats Ok.
I'm thinking now.
Old 5th May 2008, 10:37 PM
Experienced Member
are you using one of those 'breadboard' kit things,
Old 5th May 2008, 10:38 PM
Experienced Member
Can you tell which pins are which on the transistor(s)
This is necessary.
Search this Thread:
Advanced Search
Burglar alarm school project rpaus Electronic Projects Design/Ideas/Reviews 5 18th January 2007 01:11 AM
Burglar alarm madmikejt12 Chit-Chat 6 21st October 2006 11:40 AM
Adding GSM phone to burglar alarm cctv Electronic Projects Design/Ideas/Reviews 8 3rd October 2006 10:13 PM
Yet another alarm (with a laser!)... howie69 Electronic Projects Design/Ideas/Reviews 1 25th August 2006 11:05 PM
burglar alarm chriz Electronic Projects Design/Ideas/Reviews 1 21st June 2005 05:44 AM
Powered by vBulletin Version 3.5.4
Search Engine Friendly URLs by vBSEO 2.4.0
