| Experienced Member | Why is there a connection between the collector and the -ve of the siren? ********* Connecting the siren straight across the battery, would make it sound, but to control it we put the transistor in line with it. In this case the transistor collector/emitter junction controls the current for the siren, by being placed in the circuit between the siren neg and battery neg. ********* Briefly: Because the collector is the output connection of the transistor, and in this case it feeds the negative connection on the siren. **** So basically, why is everything connected in the pattern that it is? I mean, somethings, I can make out. next post ...
__________________ ************************************************** ***************** |
| Experienced Member | So basically, why is everything connected in the pattern that it is? I mean, somethings, I can make out. *************** well, that arrangement is only one possible arrangement, using the transistors and stuff that you have. That one was chosen for simplicity and basic straightforward construction, bearing in mind that you would have to be able to answer some questions about it. Other more involved circuits were mentioned, and at one stage i was wondering if single transistor would be able to do it. The basic concept is that the light affects the cell, and the cell controls the transistor, and the transistor controls the siren. The cell would not have the strength to control the siren, even if it did it would be "backwards", that is low resistance (more conductive) when light falls upon it, so the transistor 'reverses' the logic of the effect. So theres two effects to cover, one, the ABSENCE of light has to operate the siren, two, the current needed by the siren is more than the cell can control. (in this case) [hope that covers it] John
| Experienced Member | Hope i havent just made it look more complicated than it is ....
| | (permalink) | |||||
| Experienced Member | No, you haven't made it complicated. I just need some clarification. Sorry for the relentless questions.. Quote:
And also, do you know approximately how much voltage the laser (or any light source) has to provide to the photocell to turn the transistor on? I'll read that last post about why everything is connected like that now. | |||||
| Experienced Member | heres a picture of my cat:
| Experienced Member | Quote:
| Experienced Member | And also, do you know approximately how much voltage the laser (or any light source) has to provide to the photocell to turn the transistor on? ******** Well, its light really, i would say ordinary sunshine should push that sensor to maximum conductivity. Fortunately those little lasers have a pretty narrow beam, so the light intensity is pretty high in the 'spot'. At the other end however, most sensors dont start to respond until its far from being dark, usually it needs to be better than even gloomy, before a change is noticed. Unless they are more sensitive than they used to be.
| Experienced Member | And the resistor just simply controls the current. ******** Well sort of. In this case it sets the range of current that the transistor will operate within, the cell controls the output current depending on the light. The resistor is chosen, so that the base current is not too much for the cell to control, and also that it has to be enough to turn on the transistor when the cell is dark. Hope that makes sense ... the cell has direct control, the resistor sets the range. ********* I hope the questions you face are not so in-depth. John
| Experienced Member | Woah there, not at all. I just thought you could do with a laugh. You ask whatever questions you want, i will try to answer as best i can
| Experienced Member | The concept of the emitter being in both the controling current path, and also the output current path, seems to need further clarification. I will attempt to show how this occurs on the diagram. back soon. but i feel its a bit late where you are, do you want to continue, or to leave it at that ?
| | (permalink) | |||
Other than that, may you please just give brief explanations to the questions I had in the post with the 5 quotes. Quote:
| Experienced Member | I don't know if John already covered this, but remember that current flow is described two ways: "conventional flow", where we refer to current flowing from the positive terminal of the battery to the negative terminal; and "electron flow", where we refer to the fact that the electrons actually flow from the negative to the positive terminal. From a practical standpoint it doesn't usually matter which you use as long as everybody in the conversation is using the same convention. Whichever one I suggest you use in class, the teacher will prefer the other one. Torben |
| Experienced Member | Okay ... heres the first part of the explanation concerning the operation of the cell, and how the resistor sets the current range, and the cell can alter the current in the emitter/base junction.
| Burglar alarm school project | rpaus | Electronic Projects Design/Ideas/Reviews | 5 | 18th January 2007 01:11 AM |
| Burglar alarm | madmikejt12 | Chit-Chat | 6 | 21st October 2006 11:40 AM |
| Adding GSM phone to burglar alarm | cctv | Electronic Projects Design/Ideas/Reviews | 8 | 3rd October 2006 10:12 PM |
| Yet another alarm (with a laser!)... | howie69 | Electronic Projects Design/Ideas/Reviews | 1 | 25th August 2006 11:05 PM |
| burglar alarm | chriz | Electronic Projects Design/Ideas/Reviews | 1 | 21st June 2005 05:44 AM |
