| Experienced Member | Oh, ah, you helped me before I asked for it. Thank you. Yeah, hopefully it can beat the sock quarks. But honestly she didn't even deserve the relentless questioning by my teacher. I mean...quarks..how is one supposed to make a working model, or even any type of model, for those? I, myself, had 3 ideas rejected by him before he accepted one (I had to call him 2 days before our handout--a poster explaining our topic--was due to confirm!). Last edited by Anonymous321; 6th May 2008 at 04:56 AM. |
| Experienced Member | John's a trooper for sure. It's not late for me yet. By the time I go to bed John will probably be back online. Torben |
| Experienced Member | Well this is the schematic that I was able to draw on paint. It's not the best and I tried to explain all the connections. I can't believe that this is all that there is to it. I feel silly. I believe I have some questions too but I'm a little too tired to articulate them right now. I will for sure put them on...maybe a little later or after I've back from school. |
| Experienced Member | Can you post a quick photo of the circuit from above with all unused wires removed etc? The end of the battery symbol with the long line is the positive end. Torben |
| Experienced Member | Yeah sure, I was just about to. My batteries for the camera died though...like I bought it ~5.5 hrs ago and the batteries run out.. "The end of the battery symbol with the long line is the positive end." Touché. I'll fix that too. Sorry. But I'm still calling it V1! Last edited by Anonymous321; 6th May 2008 at 06:25 AM. |
| Experienced Member | Cheap batteries suck. I guess some would say you were lucky to get any pictures out of them at all. Torben |
| Experienced Member | Yeah. This camera did help me out too. Ok so a picture of my circuit and my revised schematic are up with this post. |
| Experienced Member | In the picture the circuit looks OK. I know you don't have a lot of experience drawing schematics but don't worry--that will change with time. What sorts of questions do you think the teacher is going to hit you with? Torben |
| Experienced Member | Hi Torben, Hi Anonymous, Had a good kip. Had a look at that latest picture. I think that resistor wire goes a bit too close to the collector. Maybe you could put a bit of sleeving on it ? Or if the transistor wire is thinner, maybe a bit of insulation from those red wires would fit on to that collector wire, just to save it from touching accidentally. (going to look at your little diagram) John
__________________ ************************************************** ***************** |
| Experienced Member | Hi, Just a tiny alteration, and i put the resistor in John
__________________ ************************************************** ***************** Last edited by john1; 6th May 2008 at 10:23 PM. |
| Experienced Member | Hi Anonymous, Notes/comments ... Ive changed "NPN" to transistor, cos you never know what kind of questions may get raised by someone. I thought, keep it as straightforward as possible. If you get asked 'Which bit is the transistor' thats fair enough, but what if you get asked whats NPN, or what does N.P.N. stand for, Or why use an NPN instead of a PNP, Or any kind of related questions that might throw you. I thought best just call it a transistor. **************** The battery, You may have noticed Torbens drawing of a battery is a bit longer that yours, thats cos the long and short lines are in pairs, each pair represents a 'cell' So a nine volt battery has six cells. (they are 1.5v each on that battery) Now that doesnt really matter, and unless your tutor has a background in electronics or higher physics he would be very unlikely to pick that up. So i shouldn't worry about that. If you care, an easy way is to draw the first and last cells with a dotted line joining them up. That is common practice, but i dont think you need to worry about that. ************ The resistor. If someone says 'whats that for?' ... 'why use that value?' ... 'How do you know its the right way round?' Or stuff like that, ... .Its there to turn the transistor on, 'conducting' .That value? ... tried a few values, that one was suitable. .Its the same either way round. ***DONT CLARIFY by saying ... unlike some things, which are different the other way round ... BECAUSE that may well produce another question, like, 'such as ..' or what bits are direction sensitive, why are they like that, and so on. you dont want opportunist questions coming at you. *********** How long will the battery last? Dunno, this is only a demo, a proper burglar alarm would be run from the supply, and would only use a battery as back up. ************** Any questions you think might come your way, let us know, we'll try to suggest an answer that does not invite another question! Cheers, John
| Experienced Member | Yeah, the battery symbol is just the one which Eagle added when I selected '9V battery clip'. If I was drawing this by hand I'd use the abbreviated symbol John mentioned. John's right about that resistor wire coming too close to the transistor leg. Maybe it just looks close because of the angle but better to take his advice and be safe. By the way, anon, if you are interested in doing more circuit design etc. after this project is done, there are a couple of free packages available on the net which might help. One is Eagle, which is an excellent schematic capture (drawing) program which includes a PCB layout module. Version 5.0 just came out, and a free version is available for free download: http://www.cadsoftusa.com Another is LTSpice, which you can also use for drawing schematics, but it is also a simulator, so you can get some kind of idea of whether a given circuit will work even if you don't have the components to actually build it. LTSPice is also called LTSpice/SwitcherCad III: http://www.linear.com/designtools/so...witchercad.jsp These obviously won't be any help for the current project but over time they might come in handy if you keep up with electronics. Were there any students presenting today? Any more questions from the teacher which might indicate what he'll hit you with? Torben |
| Experienced Member | Hi Torben, Its been about 18 hours, We may not hear from Anonymous again, but i would like to know how the presentation goes. John
| Experienced Member | Quote:
Torben | |
| Experienced Member | Hey John and Torben. Thanks for the responses and clarifications. I've read your suggestions. I can't believe I missed drawing the resistor in! However, I do have more questions and I hope you guys will be online to answer them before I have to present it, or rather, go to sleep. |
| Burglar alarm school project | rpaus | Electronic Projects Design/Ideas/Reviews | 5 | 18th January 2007 01:11 AM |
| Burglar alarm | madmikejt12 | Chit-Chat | 6 | 21st October 2006 11:40 AM |
| Adding GSM phone to burglar alarm | cctv | Electronic Projects Design/Ideas/Reviews | 8 | 3rd October 2006 10:12 PM |
| Yet another alarm (with a laser!)... | howie69 | Electronic Projects Design/Ideas/Reviews | 1 | 25th August 2006 11:05 PM |
| burglar alarm | chriz | Electronic Projects Design/Ideas/Reviews | 1 | 21st June 2005 05:44 AM |
