Hi all, I have made a voltage comparator out of a 5 V powered LM358N opamp and it is working just fine. But when I connect the output to digital in on a micro controller (PIC 18F4550) the voltage drops to around 0.6 V and the the low voltage is not enough to trigger the input. I have tried to remedy the problem by using the other half of the opamp as a voltage follower but with no luck. Do you have any idea to what the problem might be? Regards Drohm | |
| | #2 | |
Are you sure the PIC pin is not configured as an output.? Do you have a drawing.? BTW, you have posted this question 3 times..
__________________ Eric " Good enough is Perfect " I will NOT answer PM's requesting technical help, please use the Forum PIC tutorials: Nigel's www.winpicprog.co.uk/ Bill's: www.blueroomelectronics.com/ | ||
Hi, Yes Im sure the PIC pin is not configured as output. It works just fine if I put 5 V directly on the pin. Yeah I know it is posted 3 times Im trying to delete two of the posts ![]() I dont have a drawing at the moment, but I will make one very soon. | |
| | #4 | |
I agree with ericgibbs, you've most likely got the pin configured as an output, and set low. | ||
Yeah, you might be right. But how does that explain that it works with 5 Volts then?
| | #6 | |
| | #7 |
Ok, thanks for the help! I shall return as soon I have checked the code... | |
| | #8 | |
If you want to double check, post your code.
| comparator, connected, controller, drops, micro, output, voltage |
| micro controller projects | melodzky | Micro Controllers | 3 | 4th July 2005 08:41 AM |
| output voltage drop of 555 timer ic | mozikluv | Electronic Projects Design/Ideas/Reviews | 4 | 18th November 2003 03:49 AM |
| changing dc power supply output voltage??? | seaball | Electronic Projects Design/Ideas/Reviews | 3 | 6th August 2003 11:11 PM |
| voltage output | bogdanfirst | General Electronics Chat | 3 | 18th July 2003 07:50 PM |
| Micro Controller Switcher Help | Fuad | General Electronics Chat | 3 | 25th May 2003 08:48 AM |
