+ Reply to Thread
Results 1 to 4 of 4
Thread: Serial I/O routines in C? (no UART!)
  1. #1
    Laurie Newbie
    Join Date
    Apr 2008
    Posts
    5
    Default Serial I/O routines in C? (no UART!)
    Hi all,
    i'm trying to output a number of bytes (only 6 or 7) on one pin from a 16f684, to be recieved on one pin another 16f684.....i'm writing my program in C, and cant find much info on this at all for C programmers.....are there any downloadable subroutines that i could #include into my code that would let me just send a byte or two at a time to a 'send' function....??? (and a 'recieve' function for the other PIC that could copy the recieved bytes into my own variables/from which i could copy the recieved bytes as they come in.)
    any help or info on where i could find help would be great
    i'm using PICC Lite, MPLAB, and a PICKIT2 programmer........and it really does have to be done by 1 pin at each end.....
    thanks very much,
    L
    {edit, forgot to explain that i need a 'recieve' function too...}
  2. #2
    3v0
    3v0 is offline
    3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent
    Join Date
    Jul 2006
    Location
    USA
    Posts
    6,464
    Blog Entries
    11
    This is known as bit banging or a software UART. If you google you should find code for it on the web. Most C compilers have it as a library function. Have you checked ?
    BCHS/3v0's Tutorials
  3. #3
    Laurie Newbie
    Join Date
    Apr 2008
    Posts
    5
    yes...PIC C Lite does have a 'serial' file in the samples directory, but it seems really complex, and uses RA2&3 as I/O, whereas i need to use RC3....
    is it as simple as changing the relevent TRIS and PORT registers to change these to RC3?....i still dont understand how i'd use the functin tho; theres no obvious 'copy your byte here, then call 'sendfuncxxxx' explanation, and no readme...
    thanks for the quick response, and sorry if this is all really basic....
    L
  4. #4
    3v0
    3v0 is offline
    Join Date
    Jul 2006
    Location
    USA
    Posts
    6,464
    Blog Entries
    11
    There should be two #define's near the top of the code to select which IO lines are used. Change them from what they are to what you want to use.
    The low level IO function is putc(). It may have a slightly different name like soft_putc() but it is there. It will put whatever byte/char you send it out on the IO pin you setup.
    char x;
    x = 'A';
    putc(x);
    If you look into how printf works you will see that you can use it with the software UART too.
+ Reply to Thread
  1. Read from Serial Port (UART)
    By helz15 in forum Micro Controllers
    Latest: 25th March 2008, 08:35 PM
  2. 8051 Serial UART Problem
    By ahmedragia21 in forum 8051/8951
    Latest: 15th December 2007, 11:27 PM
  3. Need help badly on Inchworm and MPLAB
    By thushy in forum Micro Controllers
    Latest: 11th March 2007, 06:05 PM
  4. Nigel's I2C serial EEPROM routines and interrupts
    By blackman in forum Micro Controllers
    Latest: 21st October 2006, 08:04 AM
  5. Serial to Parallel
    By mstechca in forum Electronic Projects Design/Ideas/Reviews
    Latest: 30th March 2005, 04:40 AM
Tags for this Thread
