Old 4th May 2008, 09:04 AM   (permalink)
Default >4v squarewave oscillator?
I'm building this circuit: http://www.edn.com/article/CA302238.html (Yes. Again.)
I need an oscillator for it, though, and I need something that's compact and preferably doesn't require me to buy some special parts. Could someone reccomend me one? I need one that's quite small. (Ps. I have some SMT 2n2222's, if they can be used...)
EDIT: I forgot to mention, the last time, i eventually used a 74HC14 IC. But it's quite bulky, so I'm thinking of replacing it. Hence the question.
Firnagzen is offline
Old 4th May 2008, 09:17 AM   (permalink)
2 transisors and a frw other components can make a oscilator.Its not the most stable and the output is a bit smothed sqare wave.
http://www.play-hookey.com/digital/e...l_astable.html
I recomend you simply use a smd 555 timer
Il give you shocking experience.
Someone Electro is offline
Old 4th May 2008, 09:40 AM   (permalink)
I was actually trying to avoid the multivibrator for the stability issues, and anyway, the calculations then become a big headache. (What's TON, then?)
SMD 555's are a bit too fiddly for me to solder easily, and not as easy to get. (I got the 2n2222's some time ago because I had no other choice. I'd like to avoid more SMT parts, thank you very much! )
Old 4th May 2008, 09:54 AM   (permalink)
Just buy some small soldering tips and SMT becomes easy.
I hate it when people complain about how hard it is to solder simple SMT packages, all it means is they need to get a smaller tip, wear glasses and improve their soldering skills.
Screen name: Aloone_Jonez
Hero999 is offline
Have you looked at the Joule Thief it does the same job and its even smaller.
If you havn't already, Google Joule Thief
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is online now
Old 4th May 2008, 10:04 AM   (permalink)
The Joule Thief is not so efficient for Luxeon star 1W LEDs!
Hero999, I agree that SMD packages are not that hard to solder, but that's if and only if you can obtain (Read: etch) a suitable circuit board. And I don't do enough soldering to make it worth the effort to etch circuit boards, see? (And please don't tell me about surfboards, I'm trying to make this as small as possible!)
Old 4th May 2008, 10:12 AM   (permalink)
The 'JF''s transformer size/rating can be increased to easily power a Luxeon 1W LED.
Eric
PIC tutorials:
Old 4th May 2008, 10:51 AM   (permalink)
You can solder SMT components on veroboard you know. 805 SMT resistors and capacitors can easilly fit inbetween the tracks and ICs can be mounted dead bug style.
Turn the IC upside down and glue it to the track side of the board. Use fine 0.15mm solderable enamelled wire to solder the leads to the required racks.
Hero999 is offline
Old 4th May 2008, 11:39 AM   (permalink)
Yup ben there done that and works well
Old 4th May 2008, 02:01 PM   (permalink)
*Grumbles quietly*
Looks like I'm outnumbered.
Fine, I'll try the SMT 555.
Old 4th May 2008, 02:38 PM   (permalink)
The ordinary old 555 has a minimum supply voltage of 4.5V but has an output current of up to 200ma.
The Cmos 555 (LMC555, TLC555 and ICL7555) are guaranteed to work with a supply voltage as low as 1.5V but the output current is low.
audioguru is offline
pic16f628 oscillator setup question cyprio7 General Electronics Chat 1 27th September 2007 09:46 PM
FM transmitter oscillator question shehry Electronic Projects Design/Ideas/Reviews 5 21st March 2007 11:55 AM
74HC4060 chip in 32.768 khz oscillator kd4pbj General Electronics Chat 14 23rd January 2007 04:21 PM
Convert Unipolar Squarewave to Bipolar Squarewave evolive Datasheet/Parts Requests 15 5th June 2004 06:24 PM
Oscillator boy General Electronics Chat 7 23rd July 2003 06:14 PM
