| Hi, so I'm new and I just wanted to ask about building some kind of rotating device. I'm a totally electronically illiterate, so please forgive me. I'm working on a video project and for one shot I want to have the camera in the centre of a circle of people, with the camera rotating in place. I had tried using a turntable (record player) but it spun too quickly and the filmed images were blurred. I tried a number of ways of slowing down the rotation eg: putting weights on the turntable, wedging cards under the turntable, slowing it with my finger but it was hard to get a constant speed. Manually turning the turntable has the same problems! Is there a device, like an electric motor I could use that allows me to set/control the speed of rotation? I've racked my brain/s and can't come up with anything and the shot is absolutely critical to the project! Aahhh! Anyone know anything that could be useful? | |
| Get a disco ball and hang the camera from the string isnted of the ball?
| Hmmm...maybe though I'm not certain suspending the camera is going to be stable, I need a very solid locked in rotation, no wavering up and down, just around on the central axis. Is there not something like a stepper motor? I'd be greatful if someone could give me even some keywords to search out for...I literally don't know anything about this type of equipment! | |
| Well you just have to steady the camera, it wont swing up and down from the rotation just if the base moves. Anyway yes a stepper motor would be a good solution.But note that stepper motors need electronics to get going.What it basicly dose is pulse 4 windings in the right order the faster you do that the faster it spins,since each of these pulses thurns the motor a exsact number or degrees(how many depends on the motor) The down side is that they are normaly pretty noisy A nother solution is a DC motor with a rpm counter so its regulated to a constant adjustable speed.The quick way of regulating it is to simply put a nother DC motor on the same shaft and meshure its output voltage.
| Check the surplus supply and robotics places, they often have DC motors that are geared down. Look for gearhead and gearmotors. Do you have a given RPM in mind? To some degree you can change speed by changing the voltage. For example if you found a 12V 5RPM motor running it at 6 volts may give you a speed or 2RPM. Do not expect it to be linear. I am thinking a stepper motor would be too jerky.
__________________ search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) Last edited by 3v0; 4th May 2008 at 11:49 AM. | |
Once a DC gearmotor is up to speed, it should provide uniform speed if the load is balanced. The OP describes himself as "electronically illiterate". Changing speed by adding or removing a few cells is something he could do. Setting up a stepper motor may be too advanced.
__________________ search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) Last edited by 3v0; 4th May 2008 at 12:08 PM. | ||
| Intelligent digital speed control system for small truck model | classic | Robotics Chat | 2 | 8th October 2006 12:57 PM |
| Government Ignores Police Concerns In Changing Speed Limit Rules | ThermalRunaway | Chit-Chat | 5 | 20th August 2006 03:35 AM |
| Variable speed controller for 240Vac ceiling fan | Chin | Electronic Projects Design/Ideas/Reviews | 3 | 2nd May 2005 09:42 AM |
| Variable DC motor speed control | fabbie | Electronic Projects Design/Ideas/Reviews | 6 | 17th October 2004 06:14 AM |
| Variable speed DC 24V motor | raudet | Electronic Projects Design/Ideas/Reviews | 2 | 2nd July 2003 06:50 PM |
