Hi all, I have a project. I'll use a webcam to process images with a MCU. Then I'll mount it on a RC Car and make it can interact with the environment. I read that using a webcam with USB connection makes it really complex. Can I modify the webcam to get only raw image data (maybe as RGB) from webcam without USB? A friend said that, bypassing USB hub inside a webcam, we can get raw data from CMOS sensor. Is this possible? Or any other ideas? Thank you | |
If you know the CMOS sensor that is being used yeah. In theory you could work directly with the chip, but then you might as well just buy the chip and work wit it that way. You'd basically have to bypass all the circuitry except for the chip. Webcams tend to be far too fast and require far too much memory for a microcontroller to handle though. You would have better luck with a CMU Cam 1, 2, or 3, a POB Bot CAM, or hacking a Gameboy camera off ebay. These cameras are either much lower resolution, or have much more powerful processors integrated into them to offload the work from the microcontroller. 500x500 pixels x 8-bist/pixel x and 3 different colour layers = 732KBytes x10 FPS = 7.15Mbytes per second THat's a bit much for any MCU to handle, and 500x500 pixels very low resolution compared to most of the webcams available now. 1024x768 is more common, and the number of pixels increases squared with the dimension of the image. (I suggest you go monochrome anyways. 3 times less work and you don't have to correlate colours- just intensitites. It gets the job done for the most part anyways.) You might as well just buy the evaluation kit from Omnivision or something so you don't have to bypass the webcam. I keep hearing people saying they want to use a webcam because it's low cost. How low cost is low cost? Because for me, a $150 CMU Cam or evaluation kit to save you the grief and effort of having to deal with or bypass the USB is very worth it. HOw much are webcams? I doubt they cost that much less than one of the mentioned alternatives, certainly when you account for effort and probability of failure involved. It sucks but there ARE projects that exist that cannot be pursued under certain budget limitations. I've been looking at this for a long time, and I've come to the conclusion that you can just *barely* pull off something like this with a microcontroller only if it has 32K of RAM and the camera is a single layer (ie. one colour, or monochrome) 128x128 image. Anything else and the microcontroller doesn't have enough RAM anymore, let alone the speed to process the frames. A single image would take up half the RAM on the MCU so you can't do any operations that require you more frames or different versions of the frames. This means you can't do frame-frame comparisons unless you down sample the image greatly inside the MCU which takes a lot of time. For me, I decided it was not worth my time for what I would get out of it (my limitation is the cost of development tools for a processor capable of deal with such images), at least for the "from scratch" method where I use my own MCU. CMU Cam and POB Cam can do a lot more due to their integrated processors, and you can actually write your own firmware for the latest generation of CMU 3 (and you always could for the POB cam) so the PIC doesn't have to (and in most cases the PIC can't). If you look at the precoded algorithms for these two cameras, they are very simple and linear. It suggests that if you want to do anything remotely "substantial" then you must go with a (very expensive) processor- this puts it out of reach of most hobbyists. http://www-2.cs.cmu.edu/~cmucam/index.html http://www.pob-technology.com/web/index.php THen there is this one. They work over a UART itnerface (very slow for images, but at least you can work with it and output in JPEG format. They might output other formats too, I haven't checked. If they don't you're going to have to learn how JPEG works.) They also have no integrated processor you can code for so you have to use your own MCU. But they are very cheap. http://www.electronics123.com/s.nl/i...&category=-101
__________________ Tanaka Sensei (avatar) says: Please spell it "ridiculous" correctly! Not "rediculous". ^^ Last edited by dknguyen; 2nd May 2008 at 07:02 PM. | |
Thank you for your reply. I saw that CMUCam. But since I'm in Turkey, it's not a good choice to buy it especially because of shipping costs and customs problems. In fact, I want to develop a simple CMOS reader rather than buying one. Do not mind the MCU part firstly. Forget about it and lead me to raw RGB reading from a regular CMOS webcam ![]() Thanks in advance | |
you could use a CPLD and external SRAM. CPLD's are fairly cheap these days and would negate the need for lots of CMOS/TTL chips. And RAM is pretty cheap to. the CPLD controls the CMOS camera, quickly loads all the picture data into ram, then streams it out, byte by byte to the MCU. As for 'processing' I'm not sure many micro's can cope, maybe some ARM7's or possibly a DSP would be needed. Then again, I did tihnk about making a character recognition system with 'basic' parts once. Blueteethh
__________________ Inconsistency is the key to flexibility! | |
Thanks Blueteeth. But I couldn't figure out how to get raw data from CMOS sensor of a webcam directly?
| | #6 | |
| | #7 |
Or you could trust digikey to supply a Kodak part: http://search.digikey.com/scripts/Dk...me=KAC-9647-ND for 21USD. Of course there is no way a hobbyist caliber CPU could interpret the data, but since you are trying to use it I have to assume you are aware of that and are planning on a long developement on a relatively expensive part. | |
| bypass, modify, usb, webcam |
| USB Power hack with DC/DC Converter - am I crazy? | chconnor | Electronic Projects Design/Ideas/Reviews | 14 | 8th March 2008 10:13 PM |
| Help needed developing USB peripheral using HID class | Adester | Micro Controllers | 4 | 22nd November 2007 03:42 PM |
| usb interfacing problems for a waveform generator | simonharvey | Electronic Projects Design/Ideas/Reviews | 0 | 27th September 2007 12:32 AM |
| Wireless USB webcam - Capture frame | MrNobody | Electronic Projects Design/Ideas/Reviews | 17 | 24th February 2007 04:11 PM |
| webcam and microcontroller | beginner2 | Electronic Projects Design/Ideas/Reviews | 15 | 4th September 2005 08:47 PM |
