| New Member | Quote:
__________________ -Mahfuz- | |
| Experienced Member | Am I missing the point here? I understand that the idea is to create a linear ramp from an exponential decay. But why? What is so magical about the original exponential decay? If you need a linear ramp, then make one using the appropriate techniques. This makes as much sense as saying: "I have a steam engine and want to convert it into a diesel engine" Just my two Ringits worth. JimB
__________________ Experience is directly proportional to the value of the equipment ruined. |
| Experienced Member | You want an exponential input and a linear output. When the voltage is low the gain is low and then the voltage is high the gain should be very high. When the slope is positive and the reverse of that when the slope is negative. On the negative slope, as the voltage approaches zero the gain approaches infinity. This is a recipe for instability. On the positive slope side the gain is infinity at the reference voltage. It will oscillate. This sounds like a school project not a real world thing. If you want a linear ramp, make one. |
| New Member | Quote:
| Experienced Member | I think we all understand your desire for RC exponential to linear ramp. Most of us know how to make a linear ramp. None of us know how to make exponential to linear with out errors. With “analog computers” there is +, -, log, x^2, AxB and some more. Log is not very accurate. Squared is ok. How good do you want your ramp? As the exponential approaches Vref or GND the error will get bad. Search “analog computers” and see what functions there are. Then using these functions try to get from exponential to linear. I would use EXCEL to do the math. You could use spice but I like EXCEL better for math. I think you are not getting an answer, just questions because this is not simple, accurate or temperature stable. AND a linear ramp is so easy to make. |
| Experienced Member | Quote:
So why can't you use a current source charging (or discharging) a capacitor, which generates a linear ramp you can use for A/D testing? I have done this. it works. | |
| Experienced Member | Possibly becuase a fixation on a particular solution inhibits clear thinking and thoughtful consideration. But what do I know I'm just a graduate engineer sloping into retirement.
__________________ We never have time to do it right; but we always have time to do it over. |
As you say, its a case of 'thinking inside the box'.
__________________ Eric "Good enough is Perfect" PIC tutorials: Nigel's: www.winpicprog.co.uk/ Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ | |
