Old 7th May 2008, 07:27 PM   (permalink)
Experienced Member
audioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to behold
Originally Posted by crutschow
So the idea is, fix it but don't change it.
The Fuzz Face circuit is not the same today. It was designed a few hundred years ago with selected germanium transistors. It sounds different with modern silicon transistors. It also sounds different through a modern amplifier and speakers that have very low distortion.
Maybe the guitar pickups made today are also different from the old ones.
Old 7th May 2008, 07:38 PM   (permalink)
Experienced Member
blueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to behold
Send a message via Skype™ to blueroomelectronics
Use the force.
I've never found wishful thinking vs technology to be a winning proposition.
Bill
Smart Kits build Smart People
Old 7th May 2008, 08:52 PM   (permalink)
bboy_jon is on a distinguished road
look guys. The pedal i built is this
http://www.musiciansfriend.com/produ...dal?sku=151214
here is a sound file of what it would sound like
http://img3.musiciansfriend.com/dbas...face_3mono.mp3
If i plugged my guitar into that pedal it would produce that sound...or atleast something similar.
I don't have to change any parts. The components and circuit for the fuzz face works... it is known to work.
bboy_jon is offline   Reply With Quote
Old 7th May 2008, 09:02 PM   (permalink)
Experienced Member
Are your geetar and amp identical to the one in the video?
On the other hand if you're convinced the design is fine then the problem must be your assembly. Can you try it with someone else's gear?
PS AudioGuru knows his stuff, if he said it's wrong I'd listen.
Bill
Old 7th May 2008, 09:58 PM   (permalink)
Experienced Member
Bboy Jon's first post shows an expensive kit with modern silicon transistors.
He want a circuit that sounds like the extremely distorted recording that has its amp turned up so high it has feedback and produces sustain.
The recent picture of the case of a circuit has nothing to do with the circuit inside but they say it uses the obsolete old germanium transistors.
Old 7th May 2008, 10:21 PM   (permalink)
Experienced Member
Why doesn't the OP contact the manufacturer? They can often provide insight to their products.
Bill
Old 7th May 2008, 10:59 PM   (permalink)
Experienced Member
mneary is a glorious beacon of lightmneary is a glorious beacon of lightmneary is a glorious beacon of lightmneary is a glorious beacon of lightmneary is a glorious beacon of light
Send a message via AIM to mneary
Did you ever get Germanium transistors? Do you have a clue why the genuine Dunlop Dallas Arbiter Fuzz Face uses them?
If you insist that the design is correct, then you just built it wrong. So fix it already.
mneary is offline   Reply With Quote
Old 8th May 2008, 01:00 AM   (permalink)
my god, thats what i've been asking...for help on how to fix it. All the advice you guys have given me is that its a shitty circuit...
if i knew how to fix it...i wouldnt be asking you guys for help...
are you guys saying that if i get the germanium transistors than it will sound how it should?
Old 8th May 2008, 01:44 AM   (permalink)
Experienced Member
If you have built it right. And if your guitar pickup is the same. And if your amplifier sounds the same.
Old 8th May 2008, 02:11 AM   (permalink)
Experienced Member
Torben is a name known to allTorben is a name known to allTorben is a name known to allTorben is a name known to allTorben is a name known to allTorben is a name known to all
What people are saying is that there are a lot of things which go into achieving a certain guitar sound. Wonder why Jimi Hendrix could get a certain sound, but you can go out and get exactly the same gear and it won't sound the same? It's partly because of the way he chained his effects, partly because of how he played, and partly due to aftermarket mods done to his gear. Same with many others.
There is no magic box (pedal) which will give you That Sound (TM). Your guitar, its pickups, its internal electronics (if any), the amplifier, and anything else in the signal chain will affect the sound. The best anyone can do is say "yes, this pedal is performing as designed", which isn't the same thing as getting a certain sound. As already mentioned, the original circuit may have been designed to get that sound when matched with a pickup which would be loaded down the proper amount--perhaps your pickups are too loaded by the circuit, or maybe not loaded down enough. The germanium diodes should also make a difference.
Do you know exactly what gear was in the signal chain from the reference sound clip you're using? What guitar the guy was playing, what pickups he was using, what the tone and volume settings were, what the amp was, how it was mic'd, etc? Was there anything else in the signal chain?
Anyway, I'm hungry which makes me wordy. I hope you can get it sounding the way you like, but it might mean using a different guitar or altering the input stage to work better with what you have. If the circuit is working overall, the last step is to use your ears to tweak the thing to get the sound you want with the gear you have.
Torben
Torben is online now   Reply With Quote
Old 8th May 2008, 02:14 PM   (permalink)
Experienced Member
The articles about the Fuzz Face circuit say that the germanium transistors were selected for a certain sound because each one is different.
The articles describe how the sound changes (gets fuzzier) when the guitar is played very hard.
The recorded sound you like sounds very muddy in the lows and squeaky in the highs so I think the speakers had a lot to do with how it sounds.
Simple Guitar Distortion Pedal TrevorP Electronic Projects Design/Ideas/Reviews 20 12th December 2007 04:05 AM
Free Energy FAQ/Guide V2.0 TheVictim Alternative Energy 0 20th July 2007 05:55 PM
Guitar Effects madauzz Electronic Projects Design/Ideas/Reviews 3 16th May 2006 02:50 AM
Where can I get a guitar tuner built? Josephhh Electronic Projects Design/Ideas/Reviews 0 2nd September 2005 02:53 PM
