| Hello, I'm trying to integrate bicycle speed measurement into a home made controller. The struggle is to make it without any wire between the "tic" sensor and the controller. Speed counter found in the shops are wireless. I would like to kow how this wireless system works to be able to implement similar solution into my controller. I'm used to microchip products. They have rfPIC but it seems much to complicated for just a "tic" from the wheel. It would be nice to have some spec about these wireless bicycle speed counter. Many thanks in advance for your advices! Ivan | |
| Perhaps you could use a playing card or balloon attached to the bicycle frame and detect the sound to count wheel revolutions. That was fairly common practice in my childhood to make it sound like a motor. Today, I discovered it has even been patented -- in 1987. Can you believe that? | |
| Well... how to say... Thanks for your reply... Funny patent... But far from what I'm thinking of a solid solution! Thanks anyway! | |
| Why would you need wireless? What sort of range do you need? | |
| I was actually being half serious, not about the balloon per se, but the option of using sound as your "wireless" link. You felt RF was too complicated; although, I suspect RF is no more complicated and is more reliable than other wireless options. The balloon part was meant as a joke. | |
| The wireless range i need is about 2meters no more. just like the speed counter found in the shops. John, I'm glad to hear RF is not too complex. My problem is to find some chip for this very basic "tic" application. What would you suggest to start with? Or any idea on how the "commercial" speed counter works? How could I hack the "tic" receiver so then I can buy one and use the "tic" transmitter with my own receiver? I guess that could be a good solution! Thanks anyway for your replies. | |
| I have used the packaged Linx tx/rx combinations for short range (50 ft) control. There are many devices out there. Bill at Blueroomelectronics has had some posts on this forum that incorporated smaller and newer units. The signal is easily coded, so interference can be kept to a minimum. Here are a couple of leads from Digikey; although, that may not be the best source. John http://search.digikey.com/scripts/Dk...e=ATAR862-3-ND http://www.linxtechnologies.com/Docu...Data_Guide.pdf | |
| What's wrong with a magnet on the wheel, and a sensor on the forks wired to the controller (like most bike computers) - why would you want something wireless, which just requires an extra set of batteries. | |
| Magnets on the wheels would be the way to go, can't fathom why you'd need the added complexity of wireless. | |
| Dear all, What I want to know is only: how does the wireless speed counter works? Nothing else! Thanks in advance for your replies! | |
| Presumably it's a radio link, but you have the obvious problem of requiring power for it - in this case a CR2032 battery is used. Buy a bike model and strip the parts you want out of it - probably the cheapest and easiest way. | |
| Motor controller | Totally blank | Electronic Projects Design/Ideas/Reviews | 9 | 16th January 2008 02:12 PM |
| Dual counter | bananasiong | Micro Controllers | 45 | 24th March 2007 03:49 AM |
| How we can do it in Assembly..Help Needed | Ayne | Micro Controllers | 37 | 29th December 2006 06:49 PM |
| Intelligent digital speed control system for small truck model | classic | Robotics Chat | 2 | 8th October 2006 12:57 PM |
| Government Ignores Police Concerns In Changing Speed Limit Rules | ThermalRunaway | Chit-Chat | 5 | 20th August 2006 03:35 AM |
