Old 29th April 2008, 06:15 PM   (permalink)
nicho12 is on a distinguished road
Default Microphone Amplifier
Hello all,
I have a little issue here, I've been tasked with creating a Microphone Amplifier using discrete components (i.e. No opamps).
I have required specifications for the device, but i'm not really sure how to go about doing this..
The spec is:
Must be suitable for use with range of common microphone types
Capable of driving 3.2ohm 0.4w speakers
Does anybody have any experience with this? Clues would be very much appreciated or if anyone knows a full on solution, then brilliant!
Thanks for your help
N
nicho12 is offline   Reply With Quote
Old 29th April 2008, 09:33 PM   (permalink)
Experienced Member
mneary is a glorious beacon of lightmneary is a glorious beacon of lightmneary is a glorious beacon of lightmneary is a glorious beacon of lightmneary is a glorious beacon of light
Send a message via AIM to mneary
Use preamplifier http://sound.westhost.com/project13.htm to drive power amplifier http://web.telia.com/~u85920178/use/afamp-4w.htm. You may have to adapt the preamp for electret mics, and the 4W amplifier needs to be modified for 0.4W.
Be sure to give proper credit to the authors when you turn in your work. Your teacher probably knows how to use a search engine.
mneary is offline   Reply With Quote
Old 29th April 2008, 09:52 PM   (permalink)
yeah I know how to reference my sources
looks good, will look at it in a bit and check it out thanks mneary
Old 3rd May 2008, 05:24 PM   (permalink)
Ok I've pretty much made the whole circuit, except I cannot find for the life of my any 1ohm resistors that are specified in the amplifier circuit diagram.
do you think they are really necessary to have the two sets of 1 ohm in parallel? would I be okay just shorting that part of the circuit or is there a better solution?
Also couldn't get hold of a 2700 capacitor so Im using a 2200 and a 470 in parallel, should work right?
Do you know what the best way would be to alter it to amplify suitably for a 0.4w loudspeaker?
cheers,
Nick
Old 3rd May 2008, 06:45 PM   (permalink)
Super Moderator
The resistors are crucial! - DO NOT LEAVE THEM OUT!
1 ohm resistors are pretty commonplace, they are used in parallel to create 0.5 ohms, if you could find 0.5 (or 0.47) you could use those instead. All those three values are easy to find.
Old 6th May 2008, 09:58 AM   (permalink)
o lol one of my classmates insisted they were useless and shorting that part would work fine!! lol
ok Ill try and get hold of some 1 ohms or 0.5 ohms
what about editing it slightly to make it 0.4w output? any clues on that one?
thanks for your help!
Nick
Old 6th May 2008, 02:06 PM   (permalink)
Experienced Member
audioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to behold
The circuit is designed for 4W output so it uses a high supply voltage and many transistors for high current. A 0.4W amplifier would use a lower supply voltage and only 3 transistors.
0.4W RMS is a peak-to-peak voltage of 5.1V and a peak current of 318mA into 8 ohms.
If the amplifier has a power supply voltage of about 7.5 V and the output transistors are 2N4401 and 2N4403 then the max RMS output power into an 8 ohm speaker will be around 0.4W.
I simulated it. It has only 3 transistors so its distortion at 0.4W is about 10% and is lower at lower levels. Its voltage gain is about 18.
Old 6th May 2008, 02:17 PM   (permalink)
Experienced Member
Gaston has a spectacular aura about
what is the purpose of the 1 ohm resistors?
Gaston is offline   Reply With Quote
Old 6th May 2008, 02:36 PM   (permalink)
Experienced Member
The 1 ohm resistors add voltage to the base-emitter voltage of each output transistor so that there is less difference in current between transistors that have a 0.65V base-emitter voltage and transistors that have a 0.68V base-emitter voltage. You want about 15mA in the output transistors to reduce crossover distortion and 10mA in 1 ohm is a voltage of 0.015V.
Without the 1 ohm resistors, some output transistors that have a low base-emitter voltage will have an extremely high current all the time.
Old 6th May 2008, 08:27 PM   (permalink)
Experienced Member
Goal apparently is to drive 3.2 ohm speakers. Would this change anything?
Old 6th May 2008, 09:58 PM   (permalink)
this looks brilliant thanks will test it all out tomorrow, and thanks for the info on the resistors!
unfortunately we cant get hold of any 3.2ohm speakers, the only suitable ones are around 7ohm to 8ohm
would the circuit still work with something like these?
n
Old 6th May 2008, 10:13 PM   (permalink)
Experienced Member
I forgot about the 3.2 ohm speaker.
I reduced the values of some resistors so that more current can flow, increased the value of the output capacitor and decreased the battery voltage.
Now the amplifier provides 420mW into 3,2 ohms.
Old 6th May 2008, 10:42 PM   (permalink)
Experienced Member
I also haven't seen 3.2 ohm speakers for about 30 years. You must have an old text book.
The amplifier needs to be designed for the load. My 400mW amplifier that I simulated has an 8 ohm speaker.
Old 6th May 2008, 11:23 PM   (permalink)
Experienced Member
Your original post said 3.2 ohms, which is highly unusual these days. audioguru designed a circuit that works with 8 ohms. Now that you are changing to 8 ohms, the original circuit is perfect.
The leading cause of redesigns is inaccurate specs.
Old 6th May 2008, 11:30 PM   (permalink)
sniper007 has a spectacular aura about
With this resistors change class of amplifier.
There are two major products that came out of Berkeley: LSD and BSD. We don't believe this to be a coincidence. —Jeremy S. Anderson
sniper007 is offline   Reply With Quote
200 watts Amplifier help sunny152 Electronic Projects Design/Ideas/Reviews 13 19th December 2006 09:29 PM
Amplifier For GPS Reciever Johnny 5 Electronic Projects Design/Ideas/Reviews 10 23rd February 2006 05:02 PM
NEED HELP WITH DISCRETE MICROPHONE AMPLIFIER sas363 Electronic Projects Design/Ideas/Reviews 1 22nd August 2005 09:22 PM
microphone circuit amplifier with its data sheets sonaiko General Electronics Chat 9 3rd November 2004 12:27 AM
Ask for the principle of error amplifier in PWM swear_swear Electronic Projects Design/Ideas/Reviews 2 29th July 2003 01:07 AM
