Old 6th May 2008, 11:43 PM   (permalink)
Experienced Member
audioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to behold
The amplifiers I simulated are class-AB because the output transistors have about 15ma of idle current.
The 1 ohm resistors even out the huge spead between the base-emitter voltage of different transistors.
Without the 1 ohm resistors then the output transistors will either operate in class-B with high crossover distortion or in class-A with a high idle current and lots of heat.
Old 7th May 2008, 04:43 PM   (permalink)
nicho12 is on a distinguished road
awesome! you guys are geniuses!
this helps loads..but do these updated circuits still need a preamp? will the previous pre amp posted work?
cheers
N
nicho12 is offline   Reply With Quote
Old 7th May 2008, 04:59 PM   (permalink)
oh and btw that stuff about the 3.2ohm speakers coming from an old text book...it actually came directly from my lecturer, who pretty much is an old text book! haha
Experienced Member
The amplifier circuit I simulated with the 8 ohm speaker has a voltage gain of 18. Its output voltage at 400mW is 1.79V so its max input voltage is 1.79V/18= 99mV.
A microphone has an output level of from 2mV to 10mV so it needs a peamp with a voltage gain of at least 49.5.
Old 7th May 2008, 05:59 PM   (permalink)
Experienced Member
Gaston has a spectacular aura about
i thought a class A amplifier used a transistor that conducted for 360 degrees and an output capactor to get the positive and negative swing. as opposed to the push pull arangement of the class B ?
Gaston is offline   Reply With Quote
Old 7th May 2008, 06:04 PM   (permalink)
Super Moderator
No, it's merely a question of biasing.
BTW, a point Audioguru didn't mention, the most important function of the emitter resistors is to help prevent thermal runaway.
Old 7th May 2008, 06:13 PM   (permalink)
Experienced Member
so you can have a class A amp with a push pull arangement?
Old 7th May 2008, 07:32 PM   (permalink)
Experienced Member
I think there will not be any thermal runaway if the diodes are mounted on the heatsink so they are at the same temperature as the output transistors. A transistor with a heatsink tab performing as an amplified diode follows the temperature of the output transistors better than diodes.
Old 8th May 2008, 08:41 AM   (permalink)
Super Moderator
There will be without any emitter resistors, they are of more value than mounting the diodes (or transistor) on the same heatsink.
200 watts Amplifier help sunny152 Electronic Projects Design/Ideas/Reviews 13 19th December 2006 09:29 PM
Amplifier For GPS Reciever Johnny 5 Electronic Projects Design/Ideas/Reviews 10 23rd February 2006 05:02 PM
NEED HELP WITH DISCRETE MICROPHONE AMPLIFIER sas363 Electronic Projects Design/Ideas/Reviews 1 22nd August 2005 09:22 PM
microphone circuit amplifier with its data sheets sonaiko General Electronics Chat 9 3rd November 2004 12:27 AM
Ask for the principle of error amplifier in PWM swear_swear Electronic Projects Design/Ideas/Reviews 2 29th July 2003 01:07 AM
