Old 29th April 2008, 01:36 PM   (permalink)
Default Generate negative voltage
Can a 741 opamp be used to generate a negative voltage? I need to get the ouput of a dynamic mic and generate a negative voltage. If the input of the dynamic mike is 1 volt I need it to be -1. Can this be done with the 741 opamp? Is this the same as an inverting amp?
prprog is offline
Old 29th April 2008, 01:45 PM   (permalink)
Yes, assuming that the 741 has a negative power supply! Example +5 volts and –5 volts.
This is an example of an inverting amplifier.
ronsimpson is offline
Old 29th April 2008, 02:00 PM   (permalink)
As its an ac coupled amp, you can offset the opa input using a resistive potential divider.
example: if the supply to the 741 is say +12v, set the +Vin of the 741 using a pair of resistors, to +6v.
Search this forum for ac amplifiers.
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is online now
Old 29th April 2008, 02:24 PM   (permalink)
Check at http://www.analog.com for ADM8828.
It's a switched capacitor inverter. It works from +1.5 to +5.5 and can deliver a max current of 25mA. Needs two external 1µF caps only.
Boncuk
Boncuk is offline
Old 29th April 2008, 02:26 PM   (permalink)
I think you need to give more details, your current question makes no sense?.
Voltage Protection Circuit jnnewton Electronic Projects Design/Ideas/Reviews 15 20th January 2008 11:02 AM
Voltage ElectroMaster Electronic Theory 44 8th August 2007 06:35 PM
LED Project... Is the diagram correct? Maxer Electronic Projects Design/Ideas/Reviews 45 9th December 2004 04:18 PM
how can i produce a negative supply voltage from +12V? spyghost Electronic Projects Design/Ideas/Reviews 15 3rd June 2004 07:05 AM
Negative voltage from a 9V battery?! brodin General Electronics Chat 5 28th November 2003 08:10 AM
