Hi i would ask for some help as this is my idea of making it
i have 1 pressure sensor that have to control 2 VSDs (Variable speed drive) but 1 VSD i want to have an adjustable separate switching point questionmark from my side in this shematic is that i want to have some delay in switching off the 2nd VSD (i am not sure if this is the way i schould make it) Thanks in Advance Robert-Jan |
Looked thru your drawing, what is the value of the time delay required. Also at what voltage do you need the Comp to switch over.? Do you want a Delay at the Comp output when the input rises above the Set point and when it falls below.?
Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 7th July 2008 at 11:23 AM. |
Hi eric
the voltage that the comparator have to switch over is between 4 and 6 volt it is the goal to let the comparator switch direct if the the set treshhold is reach (swiching if the voltage rises over the set point) if the voltage drops down to the set point i want to have a delay of several seconds (2 til 5 seconds adjustible would be perfect but setting the delay by trial and error is for me also acseptable) to avoid nervous reactions near the switching point I had the idea to put a feedback resistor over the comparator (thats the reason the diode is still at the inverted input) for hystiresis in the system but that doesnt give me delays still than hystireses is still someting that is not out of my mind but in this design it would suply the capasitor constantly so the delay would not realy work i think Robert-Jan |
hi Robert-Jan,
Look at the attached drawing. For the switching of the Comp, to avoid 'chattering' at the switch over voltage you require some positive feedback, via the Rhysteresis resistor. The higher the resistance the narrower the 'dead band', I would suggest you start at about 4.7M for Rhys. When you add or change the value of the Rhys you will have to adjust the Set Point to compensate for the small positive feedback voltage, which will affect the Set Point. OPA's dont make good comparators, you could use a LM393 as the Comp and a LM358 as the amp. Also note the 4066 ic's dont have a high current capability, what are you driving into.?
hi eric thanks for your advice
the input impendance from the VSD is 30 k about the lm 324 you sugested the lm 393 for a comp and lm 358 for the amplifiers no doubt that they will do a better job but is the lm 324 absolut not suitable to use ???? I have to look if they have the other lm's here with a bit luck they do stock them Robert-Jan |
just another thought as i have still 3 swiches over in the 4066
i am not sure if i can leave the sensor line to the VSD floating so i could short it with another swich(4066) to the 0V still there is the risk (as both swiches are swiched simultanuasly still there could be a time differance) that there is a direct short from the buffer amp to 0V i could put a resistor in that line (10 k or is this over worried from my side ?? Robert-Jan |
The LM324 is low spec device, I would not use it as a comparator. The other point is how close to 0V do you require the outputs of the OPA and Comp to go.? Its never a good idea to leave inputs floating, a 10K from the pin to 0V should be OK.
Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ |
as the specs say for the 4066 the minimum on voltage at Vcc 12V have to be 8.4V and the maximum off voltage is than 2.4 V
so the comparator should give more than 8.5 V for the on signal and lower than 2.3V for off the amps need to giv 0v as that 0.1V will activate the drive already i still looking in the manual of the VSD if i can change that in the menu but till now i didn't find that it is possible Robert-Jan Last edited by rjvh; 30th April 2008 at 09:55 AM. |
This will be a problem, check the LM324 datasheet for the output voltage range.
Ok minimum low voltage (max tolerance) at a load of 10k
so that's not 0V i geus that i will have to dive a little more and deeper into the VSD manual it's a new type of VSD for my but it should be posible to have several setpoints in the curve and curve adjustment other wise i need more comparators and short the input from the VSD to ground at lower levels or control the VSD start stop points in the manual swich section of the drive than the comparators only need to swich a transitor i will do some home work on this Robert-Jan |
well home work done
it turns out that the VSD drive is pretty high tech and have function menus manual which you can compare to the bible (size wise) it is capable to have several set points and curve adjustments so the need for the comparator in this circuit is disapeared even an inverted input option is posible to select which is the first opamp in this shematic as i still have to drive 2 VSD units with 1 sensor i think i do still need the buffer amps Is the lm 324 a choice that will be capable to do that or it is still recomended to find an other candidate?? eric thanks for your comments and advices all the efforts are not waisted as i will build this circuit and maby still have some questions later on because with this circuit i can control much cheaper ( less advanced VSDs than this model) VSD units which i will use in the future Thanks Robert-Jan |
Good luck with the project.
| Circuit design for review | Kookie | Electronic Projects Design/Ideas/Reviews | 6 | 21st July 2003 06:53 AM |
| design problem faced on PWM brushless motor speed control | swear_swear | Electronic Projects Design/Ideas/Reviews | 0 | 23rd June 2003 01:05 AM |
| Question on designing close loop DC brushless motor control | swear_swear | Electronic Projects Design/Ideas/Reviews | 7 | 14th June 2003 06:16 AM |
| Design Control System | nono2328 | Electronic Projects Design/Ideas/Reviews | 0 | 19th April 2003 09:59 AM |
| Design Project on Temperature Control | soniya | Electronic Projects Design/Ideas/Reviews | 1 | 18th February 2003 04:59 PM |
