Old 26th April 2008, 12:22 PM   (permalink)
Question lm3914 question
how do you set up a lm3914, i need one to show 4-5v and another to show 2.5-3v, do you just use 2 pots to adjust the low and high settings to where you need them?
woa7 is offline
Old 26th April 2008, 12:44 PM   (permalink)
Look at this extract from the LM3914 datasheet, its shows what you are trying to do.
Use the formula in the sheet to calculate the 4v to 5v resistor values.
Do you follow.?
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is offline
Old 27th April 2008, 01:48 AM   (permalink)
so i adjust r1 to 1.2 then apply half the voltage i want the meter to display, then adjust r4 until the 5th led lights?
im new to electronics, so when i see "Vout = Vref (1 + R2/R1) + Iadj R2" that doesnt help so if you could give me a detailed example of how to calculate the resistor values that would help out a lot, like an example of how calculate the resistors needed for it to show 1-2v
woa7 is offline
Old 27th April 2008, 02:07 PM   (permalink)
Refer to the previously posted circuit.
For +1v to +2v input.,, 10 steps of 100mV
R1=200R variable
R2=1000R 1%
R3=1000R 1%
R4=500R variable
Set VD precisely to 1.00V [this is total span of 1V]
Set Vsig to +1.5V, adjust R4 until LED just turns ON
Do you follow .?
Eric
PIC tutorials:
Old 28th April 2008, 04:32 AM   (permalink)
can you show how you figured out the resistor values?
so you adjust R1 to set VD to the range you want the lm3914 to display? so for a 2 or 3v range, VD would be set to 2 or 3v? and once you set vd to the correct voltage you apply half of the max display voltage (for a display of 2-3v it would be 2.5v) to Vsig and adjust r4 untill the 5th led just lights?
woa7 is offline
Capacitor Charge/Discharge question ThermalRunaway General Electronics Chat 25 12th August 2008 05:48 PM
High speed data logging question cubdh23 Micro Controllers 3 19th August 2004 12:54 PM
Looping with a LM3914 (voltage->LED driver) AnArKey Electronic Projects Design/Ideas/Reviews 1 9th May 2004 11:01 PM
New guy with a simple question about the LM3914 IC...help? tim_the_toolman Electronic Projects Design/Ideas/Reviews 5 24th July 2003 04:05 AM
PBX question waqar Electronic Projects Design/Ideas/Reviews 0 30th March 2003 07:21 PM
