| Hi, I havent been on here in awhile and you guys always help me out. So thanks in advance Rick Brodersen CEO/Devloper Rick@heezy.com[/url]
__________________ \"Could a man who is knowledgeable about many things be considered wise if he did not know himself -Socrates\" | |
| I mean, for this purpose easy to build a thyristor circuit with variable delay. | |
| If I understand correctly, you have an AC power supply (wall receptacle for instance) and need to vary the speed of a DC motor? Further, the motor is rated at 130VDC? If so, this is fairly straightforward to do. Building a pwm controller is quite easy (esp since much of the work exists in many micros). The power electronics section might be more difficult. Does the pwm controller need to vary both motor speed and change direction? If your system is closed loop, you also need to consider how to determine the speed of the motor and feed it back into the control loop. | |
