Old 24th April 2008, 07:29 PM   (permalink)
korgy is on a distinguished road
Default Magnetic Sensor Diagram Help
Hey all! I am finding this forum very useful!
This may seem a bit elementary, but I am new to circuits. I am currently on a project to build a circuit for a conveyor belt that stops when it senses metal near the magnetic sensor.
I am using a 1000rpm motor that has about 1/2 HP. I want the motor to run when there is not metal, and stop when it detects metal.
Power source: 120VAC, 60hz power.
The main components are motor (have), power source (have), relay (not sure what to choose), magnetic sensor (?).
Any help is appreciated!
korgy is offline   Reply With Quote
Old 24th April 2008, 08:21 PM   (permalink)
Experienced Member
crutschow is just really nicecrutschow is just really nicecrutschow is just really nice
To select a particular sensor you need to state the size of the (magnetic) metal to be detected and the maximum distance from the metal to the sensor.
crutschow is offline   Reply With Quote
Old 24th April 2008, 08:49 PM   (permalink)
This is the sensor I am gonna use perhaps.
http://search.digikey.com/scripts/Dk...me=391-1000-ND
Old 24th April 2008, 11:46 PM   (permalink)
Experienced Member
This is a magnetic sensor which should work, provided it's sensitive enough.
To sense a magnetic material you need to place a permanent magnet close to the sensor so that its magnetic field is changed by the magnetic material as it passes, which is detected by the sensor. You will likely have to experiment some with the magnet strength and placement of the magnet and sensor to reliabily detect the material.
Old 25th April 2008, 12:21 AM   (permalink)
Thanks for the reply.
As for the schematic.. the relay should hook directly into the motor.. then from the relay the sensor then the power source? I am a bit confused.
Old 25th April 2008, 03:57 PM   (permalink)
Experienced Member
The sensor will not power the relay. The sensor is simply a bridge circuit that changes resistance with magnetic field. This causes a voltage change at the bridge output. You will need an op amp or instrumentation (differential) amplifier to amplify this voltage change.
Then you will need a relay driver at the op amp output to drive the relay coil.
The relay contacts will be in series with the motor power line to control the motor.
You will, of course, also need a DC power supply for the sensor and op amp.
Magnets and Electromagnets ElectroMaster Electronic Theory 11 27th November 2007 02:31 PM
digital display for magnetic field PratapKollu Electronic Projects Design/Ideas/Reviews 7 13th March 2007 01:19 AM
Magnetic powererd flashlight JJ91284 Electronic Projects Design/Ideas/Reviews 6 24th August 2004 02:57 AM
Need Help, Magnetic Field Detector JK108 Electronic Projects Design/Ideas/Reviews 4 30th March 2004 06:50 AM
magnetic field measurement with an RF oscillator Joop Electronic Projects Design/Ideas/Reviews 3 11th July 2003 07:57 AM
