Experienced Member
Checking thru the LM393 datasheet, there is an application circuit that meets your requirement. See attached extract from the LM393 datasheet. Its a zero crossing detector, feed the 6Vac from the mains isolating transformer into the Vin input and connect the XOR gate input to the LM393 output. Use a single +5V supply for the LM393 and XOR logic. If you cannot simulate a LM393, try any single supply comparator that you have in the sim,,, or even a good quality OPA. Lets know how the sim goes.
Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 7th July 2008 at 11:23 AM. |
Hey ericgibbs,
I've done the simulation with op-s, and everything works fine. I wanted to use a comparator because I thought they are more precise. Thanks a lot for the above circuit. One more question: Which is the max voltage that I can connect to the Vin input of LM393 in the above circuit? Do I have to change anything in the scheme if the amplitude of the sines is 5V, 12V or 15V? Thanks for everything
Experienced Member
The diode clamps that range of negative input voltage half cycles, it has a 5K1 resistor in series with the diode so the current is also limited to a safe level. If you are concerned about the higher positive half cycles, you could replace the diode with say a 3.9V zener. Do you follow that.? EDIT: added dwg
Yeah, thanks, I think this should work well, now I can finish my scheme. I'll let you know whether my teacher approved it.
| Square wave to sine wave converter | ghauri | Electronic Projects Design/Ideas/Reviews | 18 | 20th May 2008 07:15 PM |
| sine wave to square wave | jay543_uk | Micro Controllers | 17 | 1st February 2008 06:24 PM |
| square wave to sine wave | tony Ben | Electronic Projects Design/Ideas/Reviews | 2 | 26th January 2005 04:04 AM |
| LC filter- filtering a square wave to sine wave | kken6248 | General Electronics Chat | 3 | 22nd April 2004 04:31 AM |
| How can I convert a square wave to sine wave?? | kken6248 | General Electronics Chat | 6 | 1st April 2004 03:27 PM |
