Old 24th April 2008, 04:37 PM   (permalink)
Default eq lizer circuit
I plan on eliminating the diode going to ground from the + input of op amps. Maybe just ground the + inputs?? but it appears the + is kept high?
adding a transistor to the outputs of the lm3916 to sink more current and keep the leds all same brightness?
This is the basic circuit posted on ELECTRO TECH
Orginally was going to use the circuit as a 10 band eq but adding pots and concern about audio quality?
just going to do a TILT circuit and connect in parrell with this circuit.
any other suggestions?
MrDEB is offline
Old 24th April 2008, 04:42 PM   (permalink)
Default oups wrong circuit diagram
here is the correct circuit
MrDEB is offline
Old 24th April 2008, 10:34 PM   (permalink)
I can't remember the original Oriental circuit. I wish your project stayed in one thread.
The diode biases the input of the opamp at about 0.6V so that the collector of the switching transistor is at 0V without a signal. But the emitter has another diode so maybe the input of the opamp should have two diodes in series, then the input to the LM3916 will be 0V when the signal is zero.
The input of the LM391x needs a 1M resistor to ground or its input current will cause it to float high.
The max output current of the LM391x is about 30mA. The circuit multiplexes the columns so each LED will have an average current of 3mA max which is very dim. Of course the outputs of the LM3916 need a transistor to boost the current.
The switching of the transistors at the ouputs of the filter ICs might cause a buzz in the audio. Try it to see (hear).
audioguru is offline
Old 25th April 2008, 04:49 AM   (permalink)
I think this is the original Oriental circuit?
I just copied from my bookmarks.
Maybe adding transistors to the 3916 outputs and adding 750 ohm resistors to the leds as this seems to be enought brightness and only draw 5 ma per led on 12v(need to recheck)using smd leds.
as for sound I plan on not using the audio output from the display circuit as noise would be a problem.
going to run circuit in parrell w/ a TILT circuit.
MrDEB is offline
Old 25th April 2008, 01:26 PM   (permalink)
If the LEDs are 2.0V red ones and the supply is 12.0V then the driving transistors will have a saturation loss of 0.2V then the 750 ohm current-limiting resistors get 9. 8V. The current calculates to be 13mA. The LEDs are multiplexed so each lights for only 1/10th the total time so will look light a current of only 1.3mA. Very dim. The LM3916 can have output currents higher but it will get hot since the supply voltage is so high.
Old 25th April 2008, 04:05 PM   (permalink)
Default led calculator/transistor
In the Oriential circuit he has no transistors on the 3916 but yes I think it needs them to allow adquete brightness.
any suggestions. I am perplexed when it comes to calculating transistor saturation, etc. Using the led calculator http://led.linear1.org/1led.wiz
at 12v, 2.0 forward voltage, 20ma max I see a 560 ohm resistor?
just need direction on transistor usage.
As for the noise - not going to use the audio from display. Planning on a TILT circuit in parelle with display.
In addition to the 10 x 10 matrix displays (2) I am hoping to put leds behind the knobs using clear plastic rod for knobs.
could look really cool. The entire knob lights up no just a halo effect around the knob.
At present, using the Oriental circuit but going stereo w/2- 10x10 displays, a stereo TILT circuit all on one 2 sided board. Displays on seperate board.
Using expresspcb for layout
MrDEB is offline
Old 25th April 2008, 04:42 PM   (permalink)
I have a Sound Level Indicator project which is an LM3915 driving 10 pairs of LEDs in series at 25mA each and they are normal sized but very bright ones.
You are using tiny little LEDs and I don't know their max continuous current and max pulsed current. I also don't know their brightness and how bright you want them to be.
With a 12.0V supply, a 2.0V LED and transistor saturation voltages of 0.2V then your 560 ohm resistor (and the LED that it feeds) has a current of 9.8V/560= 17.5mA.
After multiplexing the LEDs will be very dim.
Old 26th April 2008, 04:08 AM   (permalink)
Default the led specs?
the yellow leds which I think are the weakest as we poped one with a 6v battery (none of the other leds poped.
they are OSRAM LY-T686
they show a pulsed current? as well as max surge current of .2A
maybe with the multiplxing we should just leave out the resistors but have a pot to adjust the led intensity? as noted in the lm3916 data sheet?
MrDEB is offline
Old 26th April 2008, 04:53 AM   (permalink)
The LEDs have a typical forward voltage of about 2.0V. The max continuous current is only 30mA. A 6V battery will cause a current of a few amps and will bust them.
The LM3916 has a max output current of only about 25mA which is fine for driving LEDs continuously but is much too low for these multiplexed LEDs.
You need to use transistors at each end of the LEDs and use current-limiting resistors then you cannot adjust their brightness with a pot on the LM3916 because the transistors are just on-off switches.
I think you should use a current in the LEDs of about 150mA and have the multiplexing operate at 1kHz then the on-time of each LED is 0.1ms which is much less than the max for high current pulses of 10ms.
Old 26th April 2008, 09:11 PM   (permalink)
Well, I think this project is perfect for what MrDEB is trying to do. Equalizer without Graphics is like car without wheels. Check the last posts
http://www.electro-tech-online.com/e...ecuencies.html
Menticol is offline
Old 26th April 2008, 09:41 PM   (permalink)
It is not an equalizer circuit anymore. Now it is an octave-band level display circuit. There is a VU meter for each octave band.
When he gets this working then he will make a separate octave-band equalizer circuit.
Old 26th April 2008, 10:52 PM   (permalink)
Well, the circuit I have mentioned is the same thing, Its'nt? measures each octave with the LM3915, and then multiplexates the data.
Menticol is offline
Old 27th April 2008, 06:47 PM   (permalink)
Default lm3916 multiplexing solution?
If I connect a transistor to the lm3916 outputs to increase the sink capbilities, have a 750 ohm resistor in series and 9 volt power supply for trsansistor switching, the leds should only draw 12ma each. being they are in parrell the current draw should be all equal so the leds woon't be dim?
biasing the transistor connected to the lm3916 outputs?
did a TINA simulation and a 500 ohm resistor ??
the rest f the circuit is the Oriental circuit.
not sure if this is correct approach?
MrDEB is offline
Old 27th April 2008, 07:22 PM   (permalink)
The LEDs are not driven in parallel.
The multiplexing by the CD4017 drives LEDs in one column (frequency band) at a time. Since you have 10 columns then each LED that is turned on is on for only 1/10th of the total time so it appears 1/10th as bright as one that is turned on continuously with the same current.
That is why I said to use 150mA in the LEDs and transistors so that they will appear as bright as an LED with 15mA continuously. Their max allowed current is 200mA for 5ms.
The 10k base resistor for the pullup transistor has a value much too high for the transistor to conduct 150mA. The output current from the CD4069 is barely enough to drive a 560 ohm resistor for 10mA base current from a 12V supply. If the supply is only 9V then the CD4069 won't provide enough base current for the transistor. Replace the weak CD4069 with a CD4049 that has much more output current. The pins are different.
Also select an output current of 10mA from the LM3916.
The outputs of the LM3916 are open collector so you will need to add 4.7k base-emitter resistors to turn off the emittr-follower transistors.
Old 28th April 2008, 03:17 PM   (permalink)
Default inserting a uln2804 or ?
Maybe eliminate the transistors and the 4049 and using a uln2804?
could make for fewer parts count?
contemplating|??
MrDEB is offline
Circuit Help skeeterb Electronic Projects Design/Ideas/Reviews 7 5th May 2008 07:10 PM
High Voltage Power Pulse Circuit Burnt Electronic Projects Design/Ideas/Reviews 6 5th March 2008 05:21 AM
Help needed Temperature circuit karenhornby Electronic Projects Design/Ideas/Reviews 0 13th February 2008 10:19 PM
Circuit auto OFF feature after no events design Uman Electronic Projects Design/Ideas/Reviews 2 3rd May 2004 06:34 AM
Circuit functioning very strange. Why? Cyclone Electronic Projects Design/Ideas/Reviews 12 4th November 2003 01:31 AM
