Hi
i try to work with oopic R+ kit on me Dell laptop. i buy a USB to RS232 dongle. I install the drivre that i get with the dongle and i can see the serial port in me device manager laptop. i start up the oopic programmer and it find the serial port also But whan i try to read or write to the kit i get a message the the progrem catnt find any oopic device whan i try to use PC it work properly what i need todo so i can use me laptop ???? thank's Northfarmer |
Super Moderator
You need a laptop with a proper serial port, oopic probably uses the serial port in a non-standard way, so a converter won't work.
I have only one laptop So i need some solution for this problem
Super Moderator
Dump the oopic's, and get some plain PIC's and a USB programmer then.
Experienced Member
I've had this conversation a number of times on another forum and it seems the USB -> Serial converters can be very hit or miss.
I use one for my Picstart Plus and it works fine but using it on my own projects through Visual Basic gives me frequent BSDs The most compatible ones seem to be the ones with Prolific chipsets if that helps. |
Super Moderator
Presumably the oopic programmer is a JDM type, and uses the port in a completely non-standard way, manually toggling the handshake lines?. This doesn't pass through a converter with any degree of success, and certainly gives no resemblance to the original timing. |
| USB Power hack with DC/DC Converter - am I crazy? | chconnor | Electronic Projects Design/Ideas/Reviews | 14 | 8th March 2008 09:12 PM |
| Usb - Rs232 | Kryten | Datasheet/Parts Requests | 10 | 7th February 2008 09:35 AM |
| USB to RS232 driver | flemmard | Electronic Projects Design/Ideas/Reviews | 1 | 6th October 2007 07:03 PM |
| usb to RS232 serial port : | simrantogether | Electronic Projects Design/Ideas/Reviews | 3 | 12th September 2007 12:04 PM |
| RS232 buffer | TDY | General Electronics Chat | 3 | 18th March 2005 08:36 PM |
