Electronic Projects Design/Ideas/Reviews Are you building an electronic project or want to? Maybe you need some assistance? Come and submit your electronic questions here and let our exprienced members find a solution.
Thread Tools Search this Thread Display Modes
Old 24th April 2008, 01:43 AM
Experienced Member
bmachining is on a distinguished road
Default current control (tricky one)
Im trying to build a DC power supply, but cannot find a circuit to suit.
I need variable current limiting, via a pot, voltage control isnt necessary.
Sounds simple, but i need it to handle up to 40V and as much current as reasonable, if i can draw 30 amps i be happy.
I have built a voltage controlled PS, with the above specs, using Lm317 and 4 mj2955, it works ok, but does produce alot of heat. But have been confused a few times on how to make this work with current limiting. PWM?
I can build, but not real flash on designing.
bmachining is offline   Reply With Quote
Old 24th April 2008, 01:46 AM
Experienced Member
dknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to beholddknguyen is a splendid one to behold
Have a comparator drive a pass transistor, and feed a current sensor output into the comparator. Adjust the comparator threshold using a pot or something. Whenever the current gets too high, the comparator's output changes such that the pass transistor turns off disconnecting all the current flow.
Disclaimer: Avatar for entertainment purposes only.
Old 24th April 2008, 01:51 AM
Experienced Member
I should mention this is for electroplating, the process needs constant current, voltage will adjust to maintain the selected current flow.
A circuit diagram would be much appreciated, as i cant design this stuff myself. But i do like building these things hehe
Old 24th April 2008, 01:52 AM
Experienced Member
Wait, are you asking about how to add variable current limiting to a voltage source? Or how to produce a current source?
Old 24th April 2008, 02:00 AM
Experienced Member
dknguyen, Which ever is more suitable/easier
I have the transformer, bridge rectifier and caps, a handy supplier of components and an unhealthy appetite for punishment!
the voltage regulator is on a small proto board so if it goes into the parts box im not worried.
Old 24th April 2008, 02:12 AM
Experienced Member
THe one I described is really current limiting. It will try and stop the current from getting too high, but doesn't stop the current from getting too low (though it will allow current to flow again once it falls below the threshold so technically it kind of does). It's not so much "variable current" by modifying the voltage or duty cycle as much as it is "bang-bang on-off". Since there is no duty cycle and there is only on or off. It's far from ideal however and there will be overshoot and undershoot but it's simple.
A time delay might need to be added somehow to the pass transistor isn't switching on and off insanely and burn out (switching also causes losses).
Old 24th April 2008, 02:32 AM
Experienced Member
Ahh ok. i do have a circuit diagram for a current limiting PS, using a UA 741, which senses voltage drop across a small resistance, which goes into a BD 149 that drives 4 of 2n3055. this works great!! But the Op amp is limited to 18V..... and i have 40v.
Old 24th April 2008, 02:36 AM
Experienced Member
SO change the opamp?
Old 24th April 2008, 02:51 AM
Experienced Member
That sounds too simple!!! hahahah
Any ideas on one that can handle the voltage?
Ps, im an engineer, not an electronics person.
Old 24th April 2008, 02:54 AM
Experienced Member
Any op-amp would do since this isn't a signal application. www.digikey.com. Search around.
The only 40V capable op-amp I have in my directories is the OP547-549 but those are high current op amps.
Old 24th April 2008, 07:16 AM
Experienced Member
Not the easiest device to find, but i have found one thats available
Texas Inst, TLE2021CPE4 Would an expert here mind checking the specs compared to a Ua741 and see if it willl work?
Old 24th April 2008, 12:26 PM
Experienced Member
Ubergeek63 is on a distinguished road
Oh yuch! Wrap appropriate components around a http://www.mouser.com/Search/Product...eLUu7A %3d%3d
a .006 ohm 10W resistor and a 0.25V max LD signal (linear dimming) with the proper IGBT and inductor running off a rectified mains will do what you are looking for.
Ubergeek63 is offline   Reply With Quote
Old 24th April 2008, 03:46 PM
Experienced Member
Ubergeek63,
a PWM power supply? I like the sound of it! More info please!
Old 27th April 2008, 05:45 AM
Experienced Member
No other ideas from anyone? Maybe a schematic?
Search this Thread:
Advanced Search
current control by microcontroller anandpatel27 Micro Controllers 3 18th January 2008 08:42 PM
Current source GagoX Electronic Projects Design/Ideas/Reviews 13 12th January 2008 06:32 PM
Voltage ElectroMaster Electronic Theory 44 8th August 2007 05:35 PM
Current and Conductivity ElectroMaster Electronic Theory 1 2nd February 2007 12:50 PM
Problems with Dual Brightness (Current) LED Tail Lights? Eagle Schematics! Ocelaris Electronic Projects Design/Ideas/Reviews 12 31st December 2006 06:18 PM
Powered by vBulletin Version 3.5.4
Search Engine Friendly URLs by vBSEO 2.4.0
