It looks as though the 741 otput is not going low enough to switch the status pin low. Not a logic '0' Do you have another comparator, a LM393 for example.???? Do not appy 9.8V to the status pin, it will damage the port.
| first thanks for replying Quote:
hi, You cannot fit a series resistor, you wll never switch off the status bit that way. The 741 amplifier cannot switch low enough to make a logic '0'. Inside the PC on the status line is a pullup resistor, the 741 cannot pull the voltage down low enough. You require a LM393 comparator.
I'm having trouble getting the MCP3202. One of the store's guy (well, I asked on 10 stores) told me the difference between linear and parallel A-D converters, and how difficult is to find MCP3202 in Bogotá (almost impossible!). He suggested me to use a parallel A-D converter (I don't remember the reference, something like ADC or 0880 8008 etc), but it's not compatible with your software and schematic, so I ignored him. What other "linear" AD converter could be used? Maybe an older one is easier to find... Thank you again!
__________________ La Rotta | ||
| Sorry by double-posting, edit was disabled Working with 74LS139 By now, I know how to cascade two of them But how can I cascade 3, or more? Thank you in advance
Use 3 of the other output pins into a 74LS138, then use the 8 decoded outputs to select the required LS139. The PC program was written for a SPI, MCP3202. dual ADC. What other SPI ADC's are available locally.? EDIT: Can you source 74154 4 to 16 mux/demux ic's locally, they are a better option than LS139's
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 27th June 2008 at 07:54 AM. | ||
| Eric, you are a nice guy, always helping peeps out. Good to know ya, don't cha know Last edited by Mikebits; 27th June 2008 at 09:14 AM. | |
| I agree Mikebits, thank you so much Eric!
| Parallel port control port: is it Write Only or Read/Write | elexhobby | Electronic Projects Design/Ideas/Reviews | 6 | 23rd December 2008 11:18 AM |
| Parallel Port & Microcontroller | Omar.M | General Electronics Chat | 10 | 14th August 2007 10:31 AM |
| Need help badly on Inchworm and MPLAB | thushy | Micro Controllers | 14 | 11th March 2007 07:05 PM |
| I need: Parallel Port.. examples and applications.. | sonaiko | General Electronics Chat | 8 | 28th October 2006 02:44 PM |
| Multiple devices controlled at once on one parallel port | Kerri Ann | Electronic Projects Design/Ideas/Reviews | 0 | 18th February 2005 11:52 AM |
