| Hi, I am trying to use a SN74LS17 family hex buffer/driver to drive 5 LEds One LED per output). My problem is that the output from each out pin from the device is at 15V and my LEDs (digikey part 160-1579-1) are rated at 5V with 20mA forward current, 100mA Peak forward current. My question is that that can I just use a resistor to make sure it just provides the right current. I calculated R to be 715 Ohm (based on 20mA,15V). Is this correct? I'll appreciate any help in this. Thanks in advance. | |
| The SN74LS17 is an odd choice as it is obsolete. The output is Open Collector which means that no current can come out of the output. Current can only go into the output. You are right that you need current limiting resistors. You always need to control the current with LEDs. The LED voltage is 3.3 V. The 5V is the maximum reverse voltage. The LEDs only light when there is forward current and voltage. No current passes when the voltage is reversed. 15V is the maximum output voltage for the SN74LS17. You can use any voltage up to 15V. 5V would seem more obvious because you must have a 5V supply to run the SN74LS17. The resistor you need is calculated with:- (Supply voltage - LED voltage)/LED current so that would be (15 - 3.3)/0.02 = 585 or (5 - 3.3)/0.02 = 85 | |
| Hi shrt, Not correct, but close enough that it would work. How did you get 715 Ohms? At first I thought you just used Ohm's Law (V=IR => 15 = 0.02 * R => 15 / 0.02 = R) but that gives 750, not 715. Anyway, the calculation you want is: Rled = (Vsource - Vled) / Iled . . .so: Rled = (15 - 5) / 0.02 Rled = 500 Ohms Your answer would have worked fine. Your LEDs would have been just a hair dimmer, is all (they'd have been limited to ~14mA instead of 20mA). For more information on LEDs and these calculations you can check out http://www.kpsec.freeuk.com/components/led.htm if you like. Good luck! Torben [Edit: Long work day and too much coffee. I jittered happily right on past the 5V LED voltage thing. Diver300 is right. | |
| I have some 3.5V blue LEDs that have a forward voltage of almost 5V when 100mA flows through them. Their max continuous current is 30mA but I blink them very brightly with 90mA.
I used the R = (15 - 0.7)/.02 to get 715. I used 0.7 as the typical voltage drop across a diode/led. Appreciate your reply. | ||
Cheers! Torben | ||
| I may have the wrong figures 15v supply, 4v forward voltage, 100ma max current? comes out at 120 ohms 1.2watt resistor http://led.linear1.org/1led.wiz | |
Torben | ||
| I haven't looked at the datasheet, what's the saturation voltage of the output transistors? Perhaps you need to factor this in to your calculations.
| The obsolete driver IC has a max allowed output current of 40mA per output. It blows up with 100mA. The 15V supply is so high that the max saturation voltage of 0.7V at 40mA and 0.4V at 16mA doesn't matter.
| Error - could not find definition of symbol 'SPBRG' | sohagiut | Micro Controllers | 28 | 19th February 2008 08:12 PM |
| pic driving shift register driving leds | Ashlume | Electronic Projects Design/Ideas/Reviews | 3 | 1st May 2007 07:10 PM |
| Introduction to High Brightness LEDs and Thermal Management | Ocelaris | Electronic Projects Design/Ideas/Reviews | 3 | 17th March 2007 06:35 AM |
| Problems with Dual Brightness (Current) LED Tail Lights? Eagle Schematics! | Ocelaris | Electronic Projects Design/Ideas/Reviews | 12 | 31st December 2006 07:18 PM |
| Driving Luxeon LEDS | archangel2 | General Electronics Chat | 13 | 19th August 2003 05:31 AM |
