I'm building a hydrogen generator as an enhancer for my jeep. To make a long story short, I need a schematic for a variable voltage supply. The criteria is 0-1 volt. This will be used to test my circuit for the effi device that I have created.
I know this is probably a simple request ,but I'm just getting back into the electronics hobby. It's been about 35 years since I tinkered with this hobby. Any help would be appreciated. Thanks Mike |
Experienced Member
It takes a massive amount of power to make hydrogen. The engine will gain a tiny amount of power from the hydrogen. You probably don't want to spend a fortune on gasoline for the engine's alternator to make hydrogen.
If you manufacture hydrogen overnight using mains electricity then it still costs more than it produces.
Uncle $crooge |
Experienced Member
Mike - you need to determine the current requirements. Is the lowest voltage really zero? Simple 3 terminal regulators only go down to 1.25 volts - but can be arranged to provide the very low or zero to some value as an output.
stevez |
Ineed to get at least below .5 volts and up to 1 volt to test my circuit. Any ideas on a setup?
Thanks Mike |
I'm trying to trick the computer in the car. The O2 sensor puts out a signal from 100 t0 800 Mv . I have created a device to set the voltage at 100 mv which will create a lean conditon. With the hydrogen supplement this will be fine. I need to test the device with the 0-1 volt reading.
Experienced Member
Did you try the pulsed electrolysis from Stan Meyer?
Instead of doing common electrolysis with poor efficiency, you can try making a train of short pulses. It seems that the efficiency increase. G |
Experienced Member
| Analog Meter | windozeuser | General Electronics Chat | 19 | 3rd October 2007 02:44 PM |
| 600v to 3.3v voltage regulator | kekek | Electronic Projects Design/Ideas/Reviews | 23 | 27th August 2007 04:02 AM |
| Current limiting Help PLZ | Frosty_47 | General Electronics Chat | 32 | 24th July 2007 03:50 PM |
| Voltage spikes through voltage regulator? | gregmcc | General Electronics Chat | 8 | 21st April 2007 05:41 AM |
| 7.6 volts from a voltage regulator | Electric Rain | General Electronics Chat | 12 | 27th August 2003 09:08 PM |
